Missing Rubber Caps
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ahmad ashfaq, Mar 22, 2015.
  1. ahmad ashfaq
    ahmad ashfaq Junior Member
    57
    islamabad islamabad
    2011 Prius Alpha
    Dear Folks,
    I found these two rubber caps(2 pieces) missing under the chasis during an oil change in the center of Prius alpha, the carpet is visible
    Can some one describe it to me what are these for?
    regards
    #1 ahmad ashfaq, Mar 22, 2015
  2. My590L
    My590L Junior Member
    42
    NorCal, CA
    If that is a photo taken from under your car, that means they did not install the proper rubber grommets from inside the vehicle during assembly in the Trim area prior to installing your carpet. These holes are necessary during the painting process to allow the ED phosphate to drain when they prep the vehicle bodies for receiving the paint as they enter and exit large tanks. Depending upon where the two rubber caps are missing, it may be fairly easy for you to install yourself. I would show it to the dealer and tell them it was a manufacturing defect that these were not installed.
    Good luck. Let us know how it works out.
    ahmad ashfaq likes this.
  3. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Dear My,
    Thanks for the reply ,
    If i wanna to install my self , do i have to detach the negative terminal of the battery to prevent airbag from opening or i just remove the seat to remove the carpet before installing them .
    regards
  4. ChapmanF
    18,260
    If you obtain the right rubber plugs, you might be able to fold and squeeze them into position from below the car without disturbing the carpet at all. It won't be totally easy because the tops are the wide parts, but they are somewhat flexible and if you can do it, and make sure the bottom lip is even all the way around, you'll be done in 5 minutes.
    -Chap
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I'm not so sure they wouldn't stay put even if you put them in upside down from the bottom. In any case there are a number of available options for hole-plugs, a internet search should reveal quite a few.
  6. Mike500
    Mike500 Senior Member
    2,593
    767
    The cap plugs are installed from the bottom; NOT from the top under the carpet. So, there is no need to disconnect the battery. Although that won't hurt anything.
  7. My590L
    42
    NorCal, CA
    I am not sure if you have to detach the negative terminal or not. If you have to unplug the wire harness from the seat, it might be a good idea. Perhaps someone else on here can fill you in.
  8. RRxing
    RRxing Senior Member
    2,548
    1,825
    NEPA
    The plugs are installed from underneath the vehicle
    ahmad ashfaq and Mike500 like this.
  9. Mike500
    2,593
    767
    The fact that there is an indented flange around the hole recessed upward into the metal explains it. That's to allow for the larger outer flange of the plug.
  10. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Thank you folks , ill try from the bottom up first , you made it easy for me .
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Side airbags are in the seat right? If true, definitely disconnect ground first!
    MT2L03 ?
  12. mikefocke
    4,010
    1,814
    Sanford, NC
    Always disconnect the 12v battery any time you are messing with anything that involves an airbag. If one of those should inflate with your head near it .....
