How do you set the clock that the GPS uses in a 2006
Discussion in 'Gen 2 Prius Main Forum' started by Trevor, Apr 13, 2006.
  1. Trevor
    Trevor Member
    352
    Staten Island, NY
    I just took my second road trip in the Prius... about 200 miles from NYC to Providence, RI. I changed the setting in the GPS to show me the time that I would arrive at the destination instead of the time left to reach the destination. For a second, I thought that the trip was a lot shorter than I expected. Then I realized that the GPS seems to have it's own clock seperate from the cars clock. The clock didn't adjust for the daylight savings time change, so the NAVd prediction of arrival time is 1 hour off.
    I stepped through a bunch of menus but I can't figure out where the time setting is. Does anyone know where the clock setting is?
  2. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    <div class='quotetop'>QUOTE(Trevor @ Apr 13 2006, 01:55 AM) [snapback]238986[/snapback]</div>
    I'm sorry. I can't answer your question, but I have one for you: How do you change the Nav to tell you when you will be arriving instead of how long it'll take? I have to try to add it up all the time.
    Thanx
  3. KMO
    KMO Senior Member
    2,004
    729
    Finland
    2023 Prius Prime
    <div class='quotetop'>QUOTE(Trevor @ Apr 13 2006, 06:55 AM) [snapback]238986[/snapback]</div>
    On the 2005, there's a time zone option, under MENU then Setup. Although this is somewhat pointless, as it doesn't actually give you an estimated arrival time - as far as I can see the time+date is only used by the calendar function.
  4. qbee42
    3,079
    GPS systems always use their own clock. The timing signals the GPS satellites are generated from atomic clocks carried on each GPS satellite, which are in turn controlled from a master atomic clock. A GPS receiver uses these signals to dertemine time and position. As a result, the time on a GPS is about as good as you can get, as long as the GPS is getting a signal from the satellites. You never need to set a GPS clock.
    That said, the problem you are having is with time zones and daylight savings time. Your GPS receiver is working off of Zulu or GMT time; it doesn't care one bit what time zone it is in or whether you are using daylight savings time. Local times are created by using their offset from GMT. For example, Eastern Time is equal to GMT - 5 hours, so we could get local times from the GPS by subtracting the offsets, but that would be a real pain to do on a routine basis. To avoind making people do that, most GPS map systems have time zones built in and do the offset calculations for you. The GPS figures out where you are, then looks to see which time zone that is, and then calculates the local time from the offset.
    There are two places where the local time calculation can go bad. One is if the local time zone is different than what is on the GPS map. This is rare, but can happen, espescially when time zones are redrawn, as they were this year in Indianna. The second place to go wrong is with daylight savings. There really is no way for a GPS to know which areas use daylight savings and which don't, other than a big database, so many GPS systems rely on the user to tell it whether to use daylight savings or not. This option will be found somewhere in the setup menus. I don't have my Prius (get it on Saturday!), so I can't tell you exactly where that option is to be found, but I have never seen a GPS map system without this setting.
    Hope this helps,
  5. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    To change from minutes to arrival to the Exact time of arrival, all you have to do is touch the screen in that area on the display.
  6. Trevor
    Trevor Member
    352
    Staten Island, NY
    <div class='quotetop'>QUOTE(qbee42 @ Apr 13 2006, 07:39 AM) [snapback]239025[/snapback]</div>
    That helps a lot... although I don't think I saw a daylight savings time anywhere or I would have figured it out. I only have the quick reference guide with me here at work and that doesn't have any DST info. Or I could just have the wrong time zone setting, but that's probably hanging out with the DST setting.
    If I want to be amused I will probably take it back to the dealer and have him be confused. He didn't even know that my car had SKS.
  7. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(Trevor @ Apr 13 2006, 01:47 PM) [snapback]239212[/snapback]</div>
    If you can't find a DST setting (I'd be very surprised), then you could just manually set the offset. EST is -5 hours from GMT, so EDT is -4 hours.
    Not that I can actually provide you with any useful information of how to do it, since I don't have Nav. :p
  8. aaf709
    3,862
    2022 Prius Prime
    Unfortunately I did see that control, but it's on the same screen that the NAV override is on. That's OK for 2004-5, but not for the 2006. :(
  9. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Yes, but having the right time in the Nav doesn't help with arrival time at all!
    The stupid nav (at least in the 2006) uses the speeds you set in the setup screen! You set the speeds for Residential, Main Roads, and Freeways. That's what it uses, no matter what your actual speed is!
    I think it's stupid (and I've said this in a thread in the Audio/Electronics forum). On local highways (not freeways), I drive 60mph but can only set 55 max in the setup screen. For freeways, you can set a max of 70mph.
    It's better than no display at all, but hardly more than that. So the "time to arrival" really means "Assuming you drive at the speeds you've entered in the setup screen, you will arrive at such-and-such a time."
  10. Trevor
    Trevor Member
    352
    Staten Island, NY
    <div class='quotetop'>QUOTE(Rick Auricchio @ Apr 13 2006, 04:17 PM) [snapback]239363[/snapback]</div>
    All nav's that I have ever used worked like that. And if I drive faster the time creeps down using the speed prefs for the remaining distance. If I get stuck in traffic, the time creeps up. I just take it as the estimate that it is.
    For longer distances, I usually find that my rest stop breaks usually balance out my time drving a bit above the speed limit so that the time ends up being just about right.
  11. acousticbiker
    acousticbiker New Member
    119
    Evergreen, CO
    The same thing happened to me RE: nav clock. There is a setting to activate DST.
  12. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(Trevor @ Apr 13 2006, 03:42 PM) [snapback]239440[/snapback]</div>
    Yeah, I'm just being too cranky about it.
  13. Trevor
    Trevor Member
    352
    Staten Island, NY
    Thanks to the hints from everyone here I figured it out. I was primarily looking for a clock setting which is what prevented me from finding it. Then I started looking for a Daylight Saving Time setting and it took me a while to realize that it was an option under the Time Zone menu.
  14. Rest
    Rest Active Member
    1,210
    CA
    <div class='quotetop'>QUOTE(Betelgeuse @ Apr 13 2006, 10:55 AM) [snapback]239217[/snapback]</div>
    I know this is an old thread, sorry but I have the incorrect time in my computer (2 hours ahead) and want to know how to change the offset. I already have the correct time zone and daylight savings time. I just need to adjust the offset and can't find where to do it.
  15. atrocity
    atrocity New Member
    And I'd love to know how to have the system display the current time. It annoys me that there's an extremely accurate clock on-board, but the only one you can actually see is the imperfect one in the dash that you have to manually set!
