Advice, please - oil filler cap left off at last service
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by enviroprius, Mar 23, 2015.
  1. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    And now you know when that happens, it is a dead give-away that the level is BELOW the end of the stick. (y)
  2. frodoz737
    frodoz737 Top Wrench
    4,652
    2,487
    33
    My father told me something along those lines when I was young...and I've told my son the same...but stuff happens. Knowledge can be taught, but wisdom comes with time/age/experience.
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    As BobWilson likes to say, pick any two ;)
  4. jdenenberg
    jdenenberg EE Professor
    3,938
    1,936
    Trumbull, CT
    2020 Prius
    LE AWD-e
    One other thing I tell my students, "experience gained is directly proportional to equipment destroyed"
    JeffD
  5. enviroprius
    enviroprius Junior Member
    91
    Sonoma, CA
    Thanks, everyone for your continued replies. The dealership continues to take my claims seriously and are keeping the car for the remainder of the week to try to figure out if something is wrong. The topic of new spark plugs came up today and I think they are going to replace them. I asked them to find another car similar to mine on their lot (they have several) and have the tech drive them back to back. It's not a perfect scenario, but maybe it will be enough for them to realize something is wrong. I'll keep you all updated. Thanks again.
  6. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Ride with them when they drive the two vehicles.
  7. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    hell, go down there and drag race the tech!!!
  8. dragonspeak
    dragonspeak New Member
    I have done the same mistake after adding oil but the smell tipped me off and I capped it after 5 miles. The oil smell went away in a couple of days. Being a quart low should not be a disaster as I have had this happen long ago a few times and now have 189000 miles.
  9. BackgammonPlayer
    BackgammonPlayer New Member
    I also have a 2007 Prius. And my oil cap was also left off (by me). Here's my experience...
    There was no smoke or anything coming out of the engine block. I only noticed the cap was missing when my red system triangle lit up and I checked under the hood. I had driven about 500 miles this way; mostly highway. I was about three quarts low. Luckily, the cap itself was originally caught when I closed my hood, so it was sitting right there.
    This whole episode was 1,000 - 2,000 miles ago. The bottom line is that there was no apparent or serious damage done, other than paying $10/quart at a remote truck stop for synthetic oil.
    enviroprius and bisco like this.
  10. bisco
    51,561
    welcome! how many miles on her?
  11. enviroprius
    91
    Sonoma, CA
    That's good to hear. Unfortunately, I continued to have problems and ended up trading it in (at the same dealer) on a new Highlander Hybrid. Good thing I did too, because I moved to where it snows (sometimes) and the roads can be pretty nasty in the winter. The AWD is much nicer in those conditions. I sure do miss my 2007 though. It was a great car. Good luck with yours!
