Air Shocks on a Prius Plug-in
Discussion in 'Gen 3 Prius Accessories and Modifications' started by virtualy, Sep 24, 2014.
  1. virtualy
    virtualy Junior Member
    34
    NorCal
    2014 Prius Plug-in
    I have a new PiP. I have a hitch mounted bike rack. I have a steep driveway. If I go slowly, I can get onto and up the driveway without grinding the hitch. But if I attach the bike rack, it is unable to clear the driveway no matter how slowly I go.
    I am looking for a solution. I have air bags on my Tundra for hauling a fifth wheel. They lift the frame. I thought that might work on the Prius to lift the frame enough to allow the bike rack to clear the street/driveway.
    Has anyone ever installed air lifts on a PiP, or any comparable Prius frame?
    Thanks.
  2. virtualy
    34
    NorCal
    2014 Prius Plug-in
  3. bisco
    51,829
    could you use different springs?
  4. peterjmc
    917
    189
    Clarksburg, MD
  5. virtualy
    34
    NorCal
    2014 Prius Plug-in
    Thanks, peter.
  6. Mendel Leisk
    41,282
    Are you going up a steep slope, then over a crest, and the crest causes the problem? Get a concrete contractor in, to smooth out that transition?
    Up the hill from us you see a lot of steep driveways with crests, they often have battle scars.
  7. virtualy
    34
    NorCal
    2014 Prius Plug-in
    No crest. Just a sharp, uphill transition from the street. Checked with city planners and concrete guy. Raising the frame, if possible, is both simpler and cheaper.
