Change auto AC's default fan speed?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by toolbox2014, Mar 25, 2015.
  1. toolbox2014
    toolbox2014 Junior Member
    36
    central OC, CA
    Each time I turn on the A/C, the fan seems automatically to be in the highest position even though the inside and outside temperature is only one or 2 degrees apart. Can this be changed? I know I can manually slow the fan down but seems like i have to do that every time I start the AC.
    #1 toolbox2014, Mar 25, 2015
  2. wickedpsi
    wickedpsi Junior Member
    Tustin, CA
    i find this annoying as well. hopefully there is a solution
  3. bisco
    51,939
    i never use auto, just for that reason. would be great to have it default to 2 or 3 bars.
  4. Mendel Leisk
    41,460
    Try raising the target temperature a degree or two. Or three. 'Till the fan speed falls back. As the car cools (and it will, even with moderately high temp set) drop the target temp incrementally, not so much that the fan races, until you reach some kind of balance.
    I find 24C good, what's that in Fahrenheit, 72?
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    75F (75.2)
  6. toolbox2014
    36
    central OC, CA
    I find the target temp has nothing to do with the fan speed. For example, the fan was went full speed when I pressed the "auto A/C" button this morning when the target temp was 72° F and the interior temp was 73°F
  7. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Try Auto in ECO mode.
  8. Mendel Leisk
    41,460
    Raise the target temp to 76~78F. Yeah, I know makes no sense, but humour me. And trust me: it'll still be cooling. Raise target temp enough and the fan speed will go down. Play with the target temp until it does. Then as the climate stabilizes start bumping the target temp down.
    CR94 likes this.
  9. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    And I think you are absolutely totally wrong in saying that.
    It may not change at exactly the points you think it should but it will change.
    And I have never noticed that "problem" with my C......or any other car for that matter.
    I sometimes think the fan should be running FASTER, not slower.......and I can get it to do that with a slight adjustment of the target temp.
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    What are you using to read interior temp?
  11. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    JD posted a good question. The temp on the display is the ambient outside temp, not the interior temp. So, if it read 73, the interior temp was probably a few to several degrees higher resulting in a high fan speed with the auto set to 72. I've had no problems with the auto setting. It comes on high when the temp diff is great and low when it isn't. I assume you don't have the defroster on, that always comes on high, at least in my experience the few times I've had to use it.
  12. Mike500
    Mike500 Senior Member
    2,593
    767
    Anyone who knows anything about air conditioning, knows that the fan must circulate air through the evaporator at a certain CFM rate or the evaporator may frost over.
    So, that is why the fan is programmed automatically for a higher speed.
  13. bisco
    51,939
    but in manual, it allows you low fan speed.
  14. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Right. Even if you're not confusing interior with exterior temperature, and are using an accurate thermometer, it makes a big difference where you're measuring the interior temperature, because of solar radiiation in the daytime.
  15. bisco
    51,939
    can't you read the interior with an obd II?
  16. Mike500
    2,593
    767
    Correct... The compressor just cycles off more often, and it will take a lot longer for the interior to cool down.
    You wouldn't want a block of ice in the evaporator. It's basic air conditioning; NO need to explain it in complicated thermodynamics.
  17. bisco
    51,939
    gotcha.(y) i kick mine on manually, start with a fan speed that suits my cooling patience, then slowly bring it down.
  18. Christian_cool
    Christian_cool Junior Member
    92
    17
    Germany
    Mine also did it. I used the downloaded app "Carista" to configure the sensitivity temperature so the fan speed is lower.
  19. macman408
    1,179
    367
    Minor detail: The Prius uses a variable-speed compressor, it's not cycling on and off.
    Also, I've tested it by manually setting the temperature to the minimum and the fan speed to the lowest, and watching the compressor power on a ScanGauge; the compressor stays at full power, even though very little air is moving. Maybe there's something else that prevents it from icing up, but it doesn't kick in right away.
  20. qdllc
    qdllc Senior Member
    1,377
    400
    I'd say live with it.
    If the outside temp is COLDER but the sun is out, the temperature in the AC unit may be high enough to make it think it needs the blower on high speed. As soon as the temperature drops in the AC vents, it will adjust automatically. This is all perfectly normal.
