  1. Sean Callahan
    Sean Callahan Senior Member
    314
    582
    Honolulu
    Awesome! How much was this whole mod?
  2. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    Ditto! Damn u haha I need!
  3. ncases
    ncases Senior Member
    609
    672
    Chicago
    Hi Sean it cost me total of close to $800.
  4. rcs3434
    rcs3434 Member
    56
    163
    Danbury, ct
    Finally was nice enough yesterday to switch my rims over to my 17" summer rims. image.jpg
    Now the struggle is waiting on my friend to help me out install my tanabe df210 springs :cautious: need wheel gap gone.....lol
  5. ncases
    609
    672
    Chicago
    Nice taillights!
    rcs3434, Dylan Doxey and mpgstho like this.
  6. VicD
    VicD Junior Member
    52
    Ohio
    Yeah, but i was more concern, does it improve the noise on the road?
  7. Ramtart
    Ramtart Senior Member
    432
    797
    San Jose, CA
    image.jpg They've arrived. BC Racing BR Series Coilovers :):):)
  8. Xterra72
    Xterra72 Senior Member
    1,436
    1,681
    Yeeaaaaah Booooooy.(y)
  9. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    Lets get those bad boys on !!!!
  10. Ramtart
    432
    797
    San Jose, CA
    I felt like a kid opening a xmas gift in the middle of March!:ROFLMAO:
  11. prius blk
    prius blk New Member
    los angeles
    My black mod
  12. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    I think it did albeit minimal. I "feel" that most of the noise is not coming across the hood but down the front side of the vehicle. Wind noise wasn't my primary concern doing this though but my CF application on the hood.
  13. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    Love those wheels! They're Konigs right? Prii have 54.1 CB so Toyota specific or any adapters?
  14. Sean Callahan
    314
    582
    Honolulu
    Ouch I was thinking $400. Haha
    ncases likes this.
  15. ncases
    609
    672
    Chicago
    Before The price was around $650 but then topsage toldme pricewent up due to led controls
    but having it Satisfice your cravings for Having it.
    #6655 ncases, Mar 26, 2015
  16. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    I finished sound dampening on the rear doors today.
    In total for the four front and rear doors, I used 5 sq ft of of Dynamat and Stinger Roadkill dampening material, about 19 linear ft of Frost King, half a roll of foil tape, a lot of my time and a few nicked/cut fingers and scraped knuckles.
    Because the rear doors have zero dampening material from the factory, I could have used a little more material, maybe another .5 to 1 more sq ft between the two of them. But, I made do with the material I had on hand and am pleased with the results.
    Results... About 4 lbs total weight added to the PIP. All four doors sound solid when you tap on them, they close with the same "thunk" as my MBZ. My unscientific before/after road noise test using an android sound meter running on my cell phone that was sitting on the passenger seat while driving the same stretch of concrete freeway at ~65ish mph... before was 89db max and after was 86db max. The crappy stock speakers seem to sound better too, although that could be a placebo effect.
    Comparing Dynamat Xtreme and Stinger Roadkill, the temperature was in the 80's and I let both materials sit in the sun before cutting and applying them. Dynamat's butyl adhesive is more firm (less sticky until you press it in place) than the butyl on the Stinger. Stinger is also slightly thicker and heavier, and I think the aluminum on the Stinger is also slightly thicker.
    Rear door with the vapor barrier removed and surfaces cleaned up, ready for me to get busy
    Peeking inside the echo chamber AKA rear door, zero dampening from the factory
    Yellow boxes are roughly where I put dampening material on the outer door skins. Minimalist but it achieved the results I was looking for while adding less than 4 lbs of weight to the car
    I reused the thinsolate material from the factory vapor barrier, attaching it onto the Frost King with foil tape
    #6656 scrappy, Mar 26, 2015
  17. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
  18. TopRamen
    307
    578
    Fremont, Ca.
  19. ncases
    609
    672
    Chicago
    I ordered mine as well. Ha
    Starbrand and Accordlayingkit like this.
  20. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Me to. I need that.
