Engine Start
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by IanIanIanIan, Mar 26, 2015.
  1. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    I have a vague memory that the PiP will start its petrol engine every XXX miles just for a maintainance warm up if it has not been used for that mileage. An engine start will reset that mileage back to zero and start recounting its EV miles until that limit is reached again.
    Please, what is that limit?
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    that limit is about 129 miles if I recall correctly but you're wrong about it resetting the mileage back to zero.
  3. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    Thank you, I wonder why such an odd number?
    The mileage I referred to is the counter to 129 miles. i.e. if there is an engine start at 62 miles the engine start counter is reset to zero so if the engine is not used again it will fire up after another 129 miles not 67. Or does it?
  4. mrbigh
    3,686
    699
    Long Island, NY
    About 206 Kilometers, and yes, it is an odd number.
  5. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    And semi-prime, too. :)
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    124 miles I think,
    when ice runs you then have another 124 miles. :)
    Edit,
    From the manual
    When continually using EV mode only
    After driving for approximately 124 miles (200 km) with the gasoline engine
    off, the gasoline engine may start for a short amount of time in order to protect
    the system.
    #6 retired4999, Mar 26, 2015
  7. bisco
    52,353
    yes, 124. no idea why so odd, amount of gas consumed? and yes, the counter restarts after the previous engine start. wouldn't it be great to be able to see it, instead of when you're pushing hard ev and surprise!
  8. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    200 km = 124.274 miles. I suspect the real number is 200km, which makes more sense (being a nice round number n' all)
    retired4999 and markabele like this.
  9. bisco
    52,353
  10. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    Any idea why they base it on distance and not on time passed by?
    For someone who does not drive much for a few months, wouldn't it be reasonable not to wait for this distance, but just start the engine once or twice a month?
  11. bisco
    52,353
    yes, that could be a real problem. but it would have to be 5 or 6 months before it would start clogging, i think. i think the manual recommends using a half tank every 6 months or something? or adding fuel stabilizer.
  12. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    If we had straight petrol instead of E10, the fuel would be stable for much longer periods of time. The car would be able to sit for over a year with the same fuel in the tank.
    Before E10 was the standard, I had cars that had sat for over 3 years and started and ran just fine on the old gas.
    The problem is that Ethanol absorbs the water and humidity in the air, and at a certain concentration of water, the engine no longer burns the fuel properly.
  13. CharlesH
    2,797
    1,165
    Roseville, CA
    But the lobbyists from the MidWest agricultural interests have made sure that use of their client's products to make the ethanol that goes into E10 is mandated. No other means to meet emissions objectives are relevant. And the fact that making ethanol from corn is inefficient from an energy perspective, and generates lots of emissions in and of itself, is irrelevant.
    :rolleyes::rolleyes:
    rxlawdude likes this.
  14. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    The Chevrolet Volt runs the engine every 6 weeks for engine maintenance and requires that the tank of fuel be kept no longer than a year.
    In order to accomplish this however the fuel tank is maintained at a positive pressure and they require that premium fuel be used.
  15. Mendel Leisk
    41,865
    I don't think the car has a permanent clock. It's got the dash clock, but that's convenience only, resettable.
  16. markabele
    5,084
    1,782
    Nebraska
    I would assume at least one of the dozens of computers in the car has a clock.
  17. Redpoint5
    1,026
    509
    Portland, OR
    I'm with Mendel on this. Most cars don't have a permanent clock because they have no need of one to operate. The clock we see is for our benefit, and isn't used as a necessary component for running the vehicle.
    Since the clock isn't necessary, it depends on a reliable 12v source of power to maintain accurate time. It's also susceptible to being programmed incorrectly by the owner, so you wouldn't want to have the operation of the vehicle rely on a setting that is easily tampered with by the operator.
    Mileage makes perfect sense. The car tracks it regardless of how reliable the 12v power source is, and it isn't easily tampered with by the owner.
  18. aljudy
    aljudy Junior Member
    17
    San Luis Obispo, CA
    2015 Prius Plug-in
    If we need gas rarely for our use, should we fill up with premium gas for its maybe better longevity in the tank?
  19. bisco
    52,353
    i would add stabilizer to the tank, such as stabile.
  20. Redpoint5
    1,026
    509
    Portland, OR
    I suppose if you're in a state where premium fuels contain zero ethanol it would keep better. However, E10 should be fine for over a year in the fuel tank of the Prius.
    In Oregon and Washington, Premium fuel still contains 10% ethanol. There are very few locations that carry ethanol-free fuel.
