2008 Prius- What I'd like from Toyota
Discussion in 'Gen 2 Prius Main Forum' started by tomdeimos, Apr 13, 2006.
  1. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    1 I like the 113 mpg! I want that for USA gallons!
    City driving. I'd settle for something over 75 mpg in highway driving at 70 mph!
    These are of course not using the plugin feature!
    2 Plug in seems to require an actual button and range read out a driver could use to get home on electric and recharge. I'd like a 20 mile electric range instead of 9, but whatever: a 9 mile range with 9 miles to work would let me drive to work on battery, drive home on gas and arrive home with a full charge and nothing to replenish overnight from the grid.
    So we need some battery range info, and a button we can push when we are that many miles from home, so we have something to recharge.
    3 I'd like the option of using no gasoline at all. Make it multi-fueled so we can use natural gas, hydrogen, or ethanol fuel too.
    4 I want more individually selectable options: that home power thing sounds good. Fancy powered seats should be an option. A second battery pack for more range would be good for electric commuters or people in mountains. etc. And a roof rack track built in would be nice.
    5 Find better tires with lower rolling resistance and better performance so we don't have to just junk the ones that come on the car and guess as to what to use. Make room for a full size spare tire too in that spare
    tire bin.
    6 Provide all info and controls for the computers that a driver could use: ie: everything the can view can do plus controls for all user servicable items like anti-freeze, brake fluid, etc and switches for all selectable options like alarm on-off, ac on off defaults, etc.
    7 Just ship the car without a radio system. Or else at least provide the rds info while driving and a better radio system. Nav controls while driving for those with that would be needed too.
    8 Give us better heater controls with their own indicator display and buttons full time with one button for air vent.
    9 With electric city driving the AC better be a heat pump this time, and the electric supplemental heat better provide around 1500 watts of heat or more for winter!
    10 Engine needs to be insulated like a stove to keep warm in winter too. Engine off should not cause engine temp to plummet as now from 160 deg to 100 in a matter of 3 minutes in cold weather!
    11 My vote would be for a lower top speed (I'd pick 80-90 max) and a higher engine non-rotating electric speed limit (say to 55 mph)
    12 Must have a second button for driver to handle! This is virtually required to get decent mpg for item 1 in highway driving. ie car must be made more aerodynamic! Get wheel skirts and the works. Lower the car. Then give us a button to jack up 6 inches for city driving or winter snows where ground clearance is a problem.
    13 Not sure of the legal hurdles but window glass should not need tinting! It should darken from the sun light itself or electrically to cut ac loading, then get light at night or on cloudy days.
    14 Put in a bigger 12 volts battery so we can run accessories parked, or leave the car for a month without worrying about it becoming discharged.
    15 Also nice to be able to start with either battery: ie grid charger could work on 12 volt battery and then that could run charge to the HV one. Then HV battery could have a mechanical override to allow a trickle charge to 12 volts if it ever went dead.
    16 Give us an aircraft accurate gallons to empty fuel gauge. And give us something better than that variable bladder capacity fuel tank we can't fill easily. With that bladder gone, should be easy to just meter the fuel from the injectors like the mpg calc, if tank could sense when it was filled full! It could be made to beep or something at some constant fill point before gas goes up the filler pipe and spills or a whistle like on your house oil tank that stops at full!
    Other than that the car is OK and don't mess with it trying to make it too like a Camry. A stretched version more like a station wagon might be a nice option though. I could see a Prius that holds 7 passengers or more luggage for families that still want good mpg.
  2. Tideland Prius
    16,602
    a Low Windshield Washer Fluid light would be nice....
    so would multi-adjustable seats
  3. gilahiker
    gilahiker New Member
    186
    New Mexico
    larger rear window wiper...dual sun visors for driver and passenger (that's about the only thing I miss about my Jimmy)...more sensitive steering wheel adjustment would all be nice
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I'd like a stiffer chassis for better handling.
    The ride height adjustment and photosensitive windows sound like great ideas. Maybe the glass could be made electrostatic, too, so the rain jumps off without the need for wipers. :)
  5. finally_got_one
    finally_got_one New Member
    151
    Orange County, California
    Stiffer Chassis, definitely.
    Put the tenths of a mile back in the Odometer.
    Make it easier to just turn on the fan w/o turning on the A/C.
    A hatch latch inside the car so that the driver can unlock the latch.
    Some sort of display to show how long one can go on battery before the ICE is going to kick in...simple predictive modelling.
    Ability to lower seats
    Inside as well as outside temp display
    Bigger 12 volt battery (but not much)
  6. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    As for "More information on the MFD", I want a series of menu option pages in which I get to choose what information is viewed and what isn't. let me decide where "information overload" exists.
    Here are a few examples:
    There are currently four little squares on the engine icon on the Consumption Screen. If I choose, I want them to tick up to indicate engine temp. Anything above two ticks should allow stealth.
    I should be able to see what he temperature inside my car is. Somehow someone installed a sensor so the Auto A/C could regulate itself. Why do you refuse to show me what that sensor says? Too much information? Let me decide.
    If I want, I should be able to choose 1- or 5- or 15-minute intervals for the graph. When I'm moving through traffic, I think I would like 1-minute, when commuting, 5-minute might be nice and when I'm on the interstate just give me 15-minute. Let me choose.
    Let me accept the responsibility of my own death and screw with the NAV / dial the phone / read the radio / and do other things while the car is in motion. If you want, make me accept my fate once a month (there's a calendar built-in).
    Lastly, but not least of all, invent a common sense syrum that I can sneak into the food and water supply to make all those gas guzzler drivers realize that they are choking the Earth and depleting our resources. If you would rather start on the low-hanging fruit I'd understand.
  7. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    Put in a telescopic steering wheel instead of that knob that substitutes for one.
    Get rid of the funky tilt wheel contraption and use a leaver like everyone else.
    Allow the tilt more range.
    Take out the build up area that the seats bolt to so that the seat will sit lower and then throw the seats away and get some comfortable 8 way electric ones. :angry:
    Remove the radio/CD from the LCD screen and put it where they have always been, the space is already there but not being used. Why do I need to screw with the computer just to see what station I listening to or what track on the CD? …… KISS.
    I don’t just want to know what track I’m on when using my CD, I want to know where on that track I am. <_<
    That’s all I can think of for now but trust me there’s more. But then I want a perfect world. :lol:
  8. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    1.Do away with the plug in idea, and instead have a form fitted solar panel roof to replensih EV battery power..
    2.Have a real stereo w/sub woofer, for those who like sound.
    3. have full ground effect model like an fx or something..
    4. better choice of rims & tires.
    5. collapsable cow catcher on the front for slow moving pedestrians. ok not really...
  9. Begreen
    Begreen Member
    670
    Western WA state
    0) LIon, plugin, with aux battery option for increased range/speed on EV
    1) a much better driver's seat
    2) get common controls - heat and radio out of the MFD
    3) Improve visibility, especially rear
    4) better tires - at least dealer upgrade options
    5) stiffer chassis
  10. RonH
    RonH Member
    556
    You guys forgot to mention: lower the price by half.
  11. Red Ginger
    Red Ginger New Member
    43
    Hawaii
    1. If they're going to keep the backup beep, at least make it useful. Perhaps a more rapid beep when less than 12" from an object?
    2. A cruise control that won't hit my knee when I turn the steering wheel.
    3. A rear armrest that lays flat, instead of at an angle.
  12. hycamguy07
    2,707
    Central Florida
    You know all these changes that everyone would like to see on these cars. Hell toyota might as well buy the patent to GMs olds delta-88 and put prius bages on it lol....
    Because if you read the posts the cars nolonger the same..
  13. Miss_Taz
    Miss_Taz New Member
    153
    Pittsburgh, PA
    Boy, I was thinking that, too! These guys want so many changes that it's a wonder they ever bought a Prius in the first place!!!
    Personally, it's already an awesome car, and my suggestions to Toyota are much less intrusive (I think). Of course, some of those "pie in the sky" type wishes above sound neat, but for the most part seem too cost prohibitive or weight prohibitive. If they put all that in there, the car would be $50k!!!
    What I'd like to see improved:
    1. Ability to use the nav system while driving
    2. Ability to use the phone via the MFD while driving
    3. Voice activated use of the BLUETOOTH features
    4. Replacement of the "fuzzy" stuff covering the center armrest and all door armrests. It is IMPOSSIBLE to keep this clean without buying a cover or adding leather.
    5. I want the doors to lock automatically when I put the car in gear. (Most other Toyotas have this)
    6. I would like the "range" (how many miles are left on this tank) feature added
    7. Would be nice to see the CD/radio song information on the MFD
    8. Easier method to transfer/enter phone #'s into the Bluetooth phonebook system
    9. Shorter delay between when you dial and when phone/Prius agree you are on the phone (not sure if this is Prius' fault or phone's or both)
    10. An option to buy a factory ready "plug-in" version would be really, really neat.
    Those are what I can think of right now...
    I *STILL* love my Prius and will love my NEW ONE in 2 more weeks!!! :D
  14. TonyPSchaefer
    14,816
    2,501
    66
    Yeah, and it should sound like the sonar beeps in a submarine. That would be cool.
  15. darkydog
    darkydog New Member
    Iowa
    Padded armrests and the console top. I always rest just my elbows on them when I drive and they are killing me if I don't put a towel or something on top.
  16. Begreen
    Begreen Member
    670
    Western WA state
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Apr 14 2006, 05:54 AM) [snapback]239649[/snapback]</div>
    Good glaven! That's a great idea.
    We have this funny panic button gift from an in-law. When you push the panic button it emits a very loud and good sampling of a submarine's "dive, dive" klaxon. Hmmm, it shouldn't take too much to wire that sucker into one of the back up lights.
  17. HTWB
    HTWB New Member
    Dublin
    Be nice to have the option of mpg on screen related to distance as well as time - so one could see the mpg over last 5 or 10 miles travelled.
  18. aaf709
    3,862
    2022 Prius Prime
    Or have it say, "Make way, make way, this Prius is backing up!" :)
  19. vk-30
    vk-30 Junior Member
    I'd like the bluetooth phone system to:
    1) Have a heirarchy - set a #1, 2, 3 thru 5 phone. Car looks for #1, and if it doesn't find it, go to #2, etc. I always have to pull over and swap phones in the screens since I drive the car less than half the time.
    2) Faster connection. I have 2 functioning bluetooth headsets, both of which connect in about 1 second or less. The car frequently takes a minute.
    3) Faster use of bluetooth when you dial from the phone itself.
    4) Don't lock out the keypad if the call was dialed from the car's screens.
    5) Make it less of a PITA to input phone #s via bluetooth, and allow typing into the car.
    Other:
    1) Option for larger battery packs and plug-in.
    2) I think they should make a 2-seat convertible version - keep the front, get rid of the back seats.
    3) Grow into a consumer electronics sort of company - charge $100 for a new software feature (Ipod connection? Ability to use skins to change the appearance of the UI? Additional info screens?).
  20. ltu1542hvy
    ltu1542hvy New Member
    338
    Cotonou, Benin
    Lots of the things already mentioned, plus:
    - adaptive cruise control
    - night vision (like the one on the new Mercedes S class
    - lane departure warning system
    - free NAV upgrades distributed via satellite and downloaded into flash RAM (instead of that DVD)
    - Options already available in non-US Prii, such as Intelligent Parking Assist, heated seats, power height adjusted seats, rear-view mirrors with integrated LCD blinkers and back-up tilt function
    - A tinted glass sunroof ("moonroof")
