MPG OverEstimate on the MFD?
Discussion in 'Prius c Fuel Economy' started by HeavyUser, Mar 31, 2015.
  1. HeavyUser
    HeavyUser Junior Member
    30
    NY
    2014 Prius c
    Hey Guys,
    I'm on my second fill up since I purchased this awesome piece of gas saving technology. My first tank said I was getting 48mpg on the MFD but fuelly calculated 46.32, my second tank said I got 50mpg on the MFD but fuelly calculated 47.97. Is this normal for there to be such a big difference in mpg between the two, do you guys have the same results with the MFD overestimating mpg?
    On a side note, a day ago I noticed my MPG was stuck at 100mpg on the energy monitor even though the car was at a complete stop. I had to restart the system to get it functioning again, do you think this could be a bug in the system? I called the dealership about it and they want me to take it in.
    A link to my fuelly:
    SippnOnsomeGassurp (Toyota Prius C) | Fuelly
    52,387
    yup. on the first question. not sure about the second. my gauge goes to zero when i stop.
  3. HeavyUser
    30
    NY
    2014 Prius c
    Oh hey Bisco, by the way that fan noise I was hearing turned out to be a bad bearing in the fan motor. The dealership replaced the radiator fan assembly.
    I did some research on the MPG getting stuck at 100mpg, found this:
    Prior reports on various Prius boards have noted other Classic Prius' Newarkitis symptoms: no charge on the battery icon, no arrow flows on the Energy Monitor, a "stuck" Consumption screen showing many consecutive 100MPG (or 0 l/100km) segments even with the engine running at idle... It will occur randomly at first, but will get progressively worse. It's only covered for the basic 3 year/36,000 mile warranty, so be careful if you're going past on mileage as it could be very expensive... Car is fully driveable, but it's mostly an annoyance. A reboot may temporarily fix the problem. Problem has been reported on US, Canadian, and Australian Prius so far that I've noted, I don't recall one way or the other on the European/UK lists.
    Just my luck, lol.
  4. bisco
    52,387
    wow, that's crazy. two defects on a fairly new car? and odd ones at that!
  5. HeavyUser
    30
    NY
    2014 Prius c
    Bought it brand new, 34miles on it.
  6. fuzzy1
    10,603
    While I can't speak to the 'c' specifically, this overestimate is normal for GenIII Liftbacks. I know of no reason why the 'c' would necessarily be different.
    The GenIIs were generally closer to reality.
  7. HeavyUser
    30
    NY
    2014 Prius c
    Have you guys noticed that even when using gas/electric(energy monitor will show gas and electric being used) the energy monitor will show 100mpg at times or could this be unique to my situation?
  8. fuzzy1
    10,603
    No, not in my Liftback.
    But we don't drive a 'c'. This part of the display is sufficiently different from the Liftback that I wouldn't draw definitive conclusions across model lines.
  9. Mendel Leisk
    41,900
    I'd read the c's and v's mpg display was at least CLOSER to reality, only about 3~4% off (guess which way :rolleyes:). Our 3rd gen hatchback's off by 7.5%, over 50,000 kms calculated.
  10. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    An mpg overestimate of 1.5-2.5 mpg (~4% at 50 mpg) seems about normal. That's what I get, and many have reported similar. SO's '12 Hyundai Accent hatchback overestimates by about 2-4 mpg (7.5% at 40 mpg).
  11. HeavyUser
    30
    NY
    2014 Prius c
    Good to know, thanks gents.
  12. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Doesn't it show 100mpg when you start off in electric mode and the gas engine hasn't come on yet? Technically in that situation it's "infinite miles per gallon", but I believe they limit the display to a maximum of 100.
    I'm in Canada, and when I start out it shows "0.0 l/100km" (litres per 100km, the way fuel economy is measured here) until the gas engine comes on and some fuel is actually consumed.
  13. HeavyUser
    30
    NY
    2014 Prius c
    In this picture I'm on a pretty flat road using the GAS engine and the ELECTRIC yet somehow it says 100mpg, it stays like this for some time unless give it more gas
  14. bisco
    52,387
    it's probably spinning the ice without using gas. keep in mind, there's a 3 second delay between reality, and what you see on the screen.
  15. HeavyUser
    30
    NY
    2014 Prius c
    I figured there was a delay yet when I switch the energy monitor over after a few minutes of the 100mpg it still show the gas/electric being used. I'll take a video later on in the week.
  16. bisco
    52,387
    you need an obd reader for instantaneous mpg.
  17. HeavyUser
    30
    NY
    2014 Prius c
    Would something like this work?
    Edit: NVM it wont let me link something to amazon. It's a bluetooth OBD reader
  18. bisco
    52,387
    i don't know. maybe someone else will. i know scan gauge works, and some phone apps. i don't have one.
  19. Mendel Leisk
    41,900
    ScanGauge will also report no gas usage, with engine turning over. The engine HAS to run, above some speed. On 3rd gen hatch it's around 74 kmh it kicks in.
  20. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    52.7 MPG actual vs. 55 MPG MDF.., I was hoping it would match
