Message flashes when turning vehicle off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Indedu78, Apr 3, 2015.
  1. Indedu78
    Indedu78 New Member
    Colombo
    This message comes on dash board when I turn vehicle off, when I used google translate the text read as 'battery remaining ht'. Should I be worried? Can someone suggest what needs to be done please. image.jpg
    51,842
    you need to have the dtc's read.
  3. Indedu78
    Indedu78 New Member
    Colombo
    Thanks for replying, what do u mean by dtc'c?
  4. alekska
    alekska Active Member
    435
    138
    Atl
    Diagnostics codes from computer
    - Alex
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    What we have here, is a failure to communicate.
    Doesn't The Prius warn you when the battery in your Fob get's low?
    I think the first thing you have to determine is why your Prius, conceivably imported to and sold in North America is evidently set to give you warning messages in Japanese.
    I'd just let a dealership navigate the language barrier.
    If it's just a warning message, there might not be any codes associated with it.
  6. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Better picture would help, but I believe the previous post above is correct, the key fob battery needs to be replaced.
    If it's been about 2 years since the fob battery has been replaced, change them. 3v lithium CR1632 button cell.
  7. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    You're assuming an awful lot.
    Judging from the license plate visible thru the windshield I'd be very surprised if he were in North America.
    I would guess Sri Lanka.
  8. The Electric Me
    9,083
    5,801
    My bad.
    I still think there is a Prius to Owner language barrier that needs to be crossed.
  9. Mendel Leisk
    41,321
  10. PriusInParadise
    180
    91
    Hawaii
    The message says that your key battery has little life remaining.
    キー     Key
    バッテリー   Battery
    残り      Remaining
    わずか      Slight
    To remedy, replace the battery in your smart key.
    #10 PriusInParadise, Apr 3, 2015
  11. Indedu78
    Indedu78 New Member
    Colombo
    Wow thanks a lot.
    And to answer your query, I'm from Sri Lanka, Colombo to be exact. We have Japanese domestic models imported and that's why the communication barrier.
    Thanks again.
  12. The Electric Me
    9,083
    5,801
    That was my guess!
