Lithium ion battery life
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Titusville, Apr 5, 2015.
  1. Titusville
    Titusville New Member
    Our 2007 prius runs and drives just fine. How can I test the remaining life in this 8 year old battery system? There are 80,000 miles on our car.
    52,421
    you can't. you can scan the batteries under load (while driving) with the correct toyota diagnostic equipment for a current health reading, but it is impossible to predict lifespan. just like you and me.:)
  3. fuzzy1
    10,603
    Note that existing regular Prii have nickel metal hydride batteries, not lithium ion.
  4. bisco
    52,421
    good point, same problem.
  5. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Make sure you get your battery fan cleaned especially if you have pets...
    Luscious Garage | Blog | Prius battery cooling fan cleaning, P0A82
    It also depends on what type of climate you live in. I live in the Interior of British Columbia and our dealership which services a city with about hundred thousand people, including many Pri taxi drivers, they have only had two gen2 hybrid battery failures total. One was a high mileage taxi, and the other was from water damage. I would imagine this is a battery failure rate of well under one per cent over more than a decade! Keep your battery cool and dry and you shouldn't even have to be concerned Imo....
  6. wjtracy
    wjtracy Senior Member
    11,372
    3,609
    Northern VA (NoVA)
    What state are you in Titusville?
    CARB warranty is 10-yrs in some states.
  7. Giarru
    Giarru New Member
    Should I take my Prius 2006 to a Toyota dealer or private mechanic to be fixed? It has been idle in my garage for two years.
  8. bisco
    52,421
    if you know a good hybrid mech, that's fine. otherwise, a dealer. you probably need a 12v battery, and then maybe a hybrid battery.
