Dash and mfd lights shut off for split second
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by av8erdunn, Apr 6, 2015.
  1. av8erdunn
    av8erdunn Junior Member
    78
    Mobile AL
    my wife has been driving the prius and has noticed that the dash and mfd lights will shut off for a split second sometimes. They always come back on rather quickly( about one second). Anyone seen this before?
    Thanks
    52,390
    fiddle with the rheostat and see if that helps. sometimes they wiggle when hitting a bump, and if they are set at full brightness, are right next to the off position.
  3. av8erdunn
    78
    Mobile AL
    I will try that this afternoon.
    Thank you.
    Edit:I asked her where the rheostat was positioned and she said it's locked in the full bright setting.
  4. bisco
    52,390
    i do the same thing. maybe back it off a speck and see what happens. there are also defective mfd's with bad solder joints, but i don't think the dash lights would be part of it.
  5. av8erdunn
    78
    Mobile AL
    Backed it off and they still come in and off every now and then. Any ideas?
  6. bisco
    52,390
    as i say, it could be a bad solder joint. can you pinpoint any particular situation when it happens? is it all on one fuse?
  7. av8erdunn
    78
    Mobile AL
    It usually happens on flat smooth ground. Not sure if they are on the same fuse. I will have to check.
