2012-2015 Prius PHV: Custom PIDs for Torque Android App
Discussion in 'OBDII Android App' started by usbseawolf2000, Mar 10, 2012.
  1. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Hi Cave Arnold,
    I've checked your raw values, they do seem to flip between the min and max. I 've a log file captured by Techstream on a Gen3:
    The correct range seems to be small and centre around zero. Therefore, I suspect all your max. values are negative values. Please help to test the formula as below:
    Column 1
    0 [TH]Name[/TH][TH]ShortName[/TH][TH]ModeAndPID[/TH][TH]Equation[/TH][TH]Min Value[/TH][TH]Max Value[/TH][TH]Units[/TH][TH]Header[/TH]
    1 [TR][TD]FR Wheel Acceleration[/TD][TD1]FR WA[/TD1][TD1]2142[/TD1][TD1]SIGNED( A ) * 199.27 / 127[/TD1][TD1]-10[/TD1][TD1]10[/TD1][TD1]m/s2[/TD1][TD1]7B0[/TD1][/TR]
    Vincent
  2. Cave Arnold
    Cave Arnold Member
    64
    60
    Lehigh Valley, PA
    I am attaching the results in a spreadsheet along with a screenshot to show the modified PID in Torque. This time it showed zeros and some weird characters occasionally. I also include FR Speed for reference. TorqueNewPID.png
  3. Cave Arnold
    Cave Arnold Member
    64
    60
    Lehigh Valley, PA
    Sorry, I just realized I left out the * 199.27 / 127. I will change for my drive in tomorrow. I do not think multiplying by ~1.6 will make a difference, but I will try anyway.
  4. vincent1449p
    894
    331
    Singapore
    It is likely the SIGNED() function is not working. If that is the case, try this:
    Column 1
    2 [TR][TD]FR Wheel Acceleration[/TD][TD1]FR WA[/TD1][TD1]2142[/TD1][TD1]( A - {A:7} * 256 ) * 199.27 / 127[/TD1][TD1]-10[/TD1][TD1]10[/TD1][TD1]m/s2[/TD1][TD1]7B0[/TD1][/TR]
    Vincent
  5. Cave Arnold
    Cave Arnold Member
    64
    60
    Lehigh Valley, PA
    I think we have a winner. I need to try and correct the sign. I tried -( A - {A:7} * 256 ) * 199.27 / 127 on the way home and that did not seem to work. I will try ( A - {A:7} * 256 ) * -199.27 / 127 tomorrow and see how that works out. Thanks for your help.
    Attached are the acceleration and speed of each wheel on my trip home. This will be helpful if I am ever in a situation where I need to accelerate or decelerate quickly otherwise it does not seem to tell me much as the small acceleration and speed changes don't seem to align well when I am cruising along.
  6. vincent1449p
    894
    331
    Singapore
    It is a two's complement number. It does not make sense to correct the sign. The formula may need to tweak further because the positive numbers are not showing up.
    Don't confuse vehicle acceleration and wheels acceleration. Some of the wheels may be decelerating even when the vehicle is accelerating, e.g. during cornering, driving over a surface with different surface friction characteristics, etc. It may not be helpful to you but the Skid Control ECU needs these info. to know whether the wheels are slipping and to effect VSC or TRC operation accordingly.
    Vincent
  7. Cave Arnold
    Cave Arnold Member
    64
    60
    Lehigh Valley, PA
    I was thinking about it incorrectly, thanks. The numbers were just not making sense in that context.
    The sign change does allow the numbers to make sense to me though as I think of + as forward and - as reverse. I intentionally accelerated in a right turn the other day and saw larger positive numbers which make sense to me. I was also seeing way to many negative accelerations during normal highway driving. It may not be technically correct, but this is the way my mind understands it best.
  8. Vostradamus
    Vostradamus Junior Member
    I'd like to test your app with my ELM327 device. Haven't been able to get Android Torque to work.
  9. Todor
    Todor Junior Member
    85
    2013 Chevy Volt
    Well, the app doesn't need testing anymore because it's already released :) But you can definitely get it and use it. It's called "Carista OBD2" and you can find it on Google Play Store. More info at Carista OBD2 - Vehicle Diagnostics and Customization | brew your own car
    Also, see this thread: Carista OBD-II application rocks | PriusChat
  10. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    Sorry, I'm a bit of a Torque newb, but I haven't seen this issue addressed:
    Is there a PID that indicates a current "mi/Kw" reading? (sort of an instantaneous MPG reading for EV mode) I would find this incredibly helpful, as the MPG reading of 100(instant)/999(ave) is completely useless in EV mode, and I find it annoying that Toyota didn't come up with a better solution out of the box.
    markabele likes this.
  11. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Hi all,
    So, I finally decided to buy myself an OBD tool to use on my PiP, and ended up in this thread to get Torque's custom PIDs.
    I have two questions to you all, for starters regarding the battery voltage pids as stated in the first post:
    1st question: Where did these 14 tension values came from?
    I thought the PiP traction battery had 4 modules, each one with 14 cells, all connected in series. Is this not correct?
    If this is true, then how do the PIDs show only the voltage for one single module (14 cells values)? Are we missing the other module's PIDs?
    2nd question: Are the attached files updated?
    I downloaded the zip file, opened the 3 comma separated files inside, and found only battery PIDs for 8 cells, it starts at V1 and finishes at V08.
    Where are the rest of them from V09 to V14?
    Cheers,
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    14 Blocks are from a regular NiMH Prius.
    For PiP with Lithium battery there are only 8 blocks. I never cleaned it up and removed V9-V14. I should update it.
    jprates likes this.
  13. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Hummm... most interesting, many thanks for that info/update USBseawolf2000!
    So we have 8 blocks of 7 cells each... with one voltage sensor and one internal resistance per block...
    Strange we only got 3 temp sensors... we are probably missing one... or am I missing yet another detail?
    #193 jprates, Apr 7, 2015
  14. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    8 blocks with 6 cells each.
    3.6v x 6 = 21.6v per module
    21.6v x 2 = 43.2v per block
    43.2v x 8 = 345.6v per pack
    There are three blower fans so I think it makes sense to have only 3 temp sensors.
  15. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Sorry, that can't be right.
    We have 3,7 V cells, not 3,6 volts, and we have 56 cells, not 96, for a total of 207,2 volts.
    The values you mention are consistent with the prototype/trial model, not the production model.
    Agree, never thought of that, it does make sense.
    I was looking at it on a different perspective: having 1 sensor for each pair of blocks.
  16. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    My bad, you are absolutely right. I was looking at the prototype spec to refresh my memory.
    This has the correct info: Prius PHV - Production battery cells | PriusChat
    So, 7 cells at 25.9v. I recall Torque shows about 28v when fully charged.
  17. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    That's it, no worries, thank you for clarifying the number of modules, I was mistaken in that regard.
    Now my next task is to change all these formulas to metric units...
  18. usbseawolf2000
    14,487
    2,996
    Fort Lee, NJ
    There is a csv file with metric unit in the zip file.
    I think Japan uses metric so they are originally metric. I had to convert them to US and US formulas are more complicated due to that.
  19. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Can't find the metric file, but no worries, I am almost done reverting it back to scientific/metric units.
    There is only one unit that I can't understand what you did on the PIDs... the temperature ones...
    The conversion should be 1.8 ºF (9/5 in your formula) for each 1ºC delta, plus 32 ºF (0ºC = 32ºF) to get from ºC to ºF.
    I can see however that you used a basevalue of 40 instead of 32 for most formulas, and on some others you even went further and used 58 instead.
    Can you please let me know if these induced "errors" are there on purpose to correct something, or if they are just typos?
    Thanks once again, and sorry for so many questions in so little time ;)
  20. EVplus
    EVplus Junior Member
    Germany, Rheinfelden
