Fresno area P3 owners...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by gaffman, Apr 10, 2015.
  1. gaffman
    gaffman New Member
    with ability to program out reverse tone and door locks?
  2. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    Not going to be in Fresno per se. Next Thursday I'll be heading across 7th Standard from I-5 to 99.
    I will be in Bakersfield next Thursday(April 16th) evening, and can customize settings if you want to meet there.
    #2 sfprankster, Apr 10, 2015
  3. bisco
    51,256
    can you make it to avi's automotive?
  4. gaffman
    gaffman New Member
    Thanks for your reply. I am giving this serious consideration and will let you know by tomorrow (4/14).
  5. gaffman
    gaffman New Member
    Where and when?
  6. bisco
    51,256
    i think he's in the l.a. area.
  7. gaffman
    gaffman New Member
    Are you comfortable making the changes I want? Do you have experience doing it? Thx
    Btw, my brother is the foremost Pinot expert. Check out his site at princeofpinot.com
  8. sfprankster
    444
    490
    You can make the customizations of your choosing.
    Simple and easy. I'm going to hook up an OBD II scanner and use an app on my phone. Takes longer to wait for the bluetooth to connect, than to actually make the changes.
    Reverse beeper, I believe, can only be turned to repeating or a single beep. Completely turned off could be possible if is different on a 2012, than on my 2014.
    What do you want to do with the door locks?
    All unlock or only the driver's door with the SKS entry?
    All lock when placing into "D"?
    All lock when @ 10 MPH?
    All unlock when placed into "P"?
    There a few more that can be changed.
    There's a good possibility I may have already met your brother.
    Just a few Pinot Events in which I participate:
    Pinot Summit-San Francisco
    Pinot Days San Francisco
    Pinot Days Southern California-LA
    Pinot Paradise-Saratoga, formerly Campbell
    Pinot on the River-Healdsburg
    #8 sfprankster, Apr 13, 2015
  9. gaffman
    gaffman New Member
    I want to get rid of the repeating beep while in reverse. Single beep I can live with. Btw, I have a 2014.
    As far as locks go, I just want all doors to unlock when I touch the driver side handle--like on the passenger side.
    What time do expect to be at 7th Standard and 99?
    Thanks
  10. sfprankster
    444
    490
  11. ncases
    ncases Senior Member
    609
    672
    Chicago
    There is an instruction to unlock all doors in your manual. Welcome to prius chat. We are here and happy to help you.
  12. sfprankster
    444
    490
    Send me a text/call and I'll give you a heads up on when I'll be near 7th Standard/99. I'm trying for closer to 5, than 7.
    Edit Friday 10:48am:
    I have a 5 hour+ drive(plus a pair of appointments enroute) and haven't heard anything, so I guess you have made other arrangements. I won't be online to check messages and/or posts here. The only way you will be able to reach me is via the phone number I PM'd you to meet.
    #12 sfprankster, Apr 15, 2015
