sfprankster's (mis)adventures modding a 2014 Prius Model Three
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sfprankster, Oct 2, 2014.
  1. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    @sfprankster When you have ordered from AliExpress what shipping have you been choosing? ePacket? Which means 7 days processing and 15 days shipping if I understand correctly? Also how have you been paying....bank transfer or just cc?
    Thanks!
  2. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    For shipping, I just use the ePacket option.
    Sometimes the package arrives in a few days(5-7)...
    ..others have taken over a month... :cautious:
    As for payment, I have a CC that I use only for overseas purchases and nothing else. :cool:
    Accordlayingkit likes this.
  3. Accordlayingkit
    1,618
    1,748
    377
    hey bro.....you or anyone else happen to know how to get the door off the compartment above the glove box?
  4. sfprankster
    444
    490
    I haven't had to remove it for anything yet.
    I just tried some pressure(pressing outwards) on the insides of the guides and there's not enough room to get them to release.
    Looks like you might have to remove the dash pieces with the air registers nearest the window and the center console section with the cup holder, to access any tabs holding the upper cover's guides to release it.
    But, just a guess...
  5. Accordlayingkit
    1,618
    1,748
    377
    Dang...
  6. sfprankster
    444
    490
    A "Cool Kids Club" (mis)adventure... :p
    Beat-Sonic FDA31-070 Shark fin antenna:
    This package arrived a week or two ago, along with a couple others I have already installed(TRD gas cap cover and JDM headlight eyebrow garnish) from a friend on vacation touring Japan and southeast Asia. The Beat-Sonic FDA31-070 shark fin antenna is a simple, straightforward mod to install. The antenna comes with three screws(I used the middle sized screw) to connect the coiled antenna to the original antenna mount, an alcohol wipe to clean the mounting area and the color matched shark fin cover. I gave the cover a quick polish and wax before mounting it to the Faux Five Prius.
    The hardest part of this mod is aligning the shark fin. :(
    I aligned the shark fin with the rear window nozzle, the wires of the rear window defrost and also by measuring between the black trim running parallel to the antenna cover. Once I was satisfied with the alignment, I used a couple of layers of masking tape to mark the sides and rear of the mounting location. I then cleaned the mounting area to remove any wax or contaminants with the alcohol wipe. I peeled a couple of small portions of the backing on the double sided tape, leaving several tabs sticking out and aligned the shark fin with my masking tape jig. The folds of the backing will hold the cover slightly above the roof and allow you to move the cover against the masking tape. Do not apply pressure to the shark fin cover until you have the alignment set. Once aligned, pull the backing tabs to expose the double sided tape and apply pressure evenly around the cover to give the tape the best chance to adhere to the roof of the car. I would recommend attempting this mod in warmer temperatures(70-80F). If attempted in cooler weather, a hair dryer could be used to warn the roof surface before applying.
    IMG_6980.JPG IMG_6982.JPG IMG_6985.JPG IMG_6987.JPG IMG_6990.JPG IMG_6992.JPG IMG_7005.JPG
    Another (mis)adventure at the spa... :rolleyes:
    Washed and a Brazilian wax:
    #206 sfprankster, Apr 9, 2015
    slfare, Blizzard_Persona and ftl like this.
  7. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    sfprankster your getting up there on aftermarket mod. You passed the $10K in parts + labor yet? I expect stereo run you good 2K+ another 1K for rims and tires. It build up quick. I just ordered my stage 10 and Piano steering wheel
  8. sfprankster
    444
    490
    Truthfully, I try not to think about it... :whistle:
    I completed most of the mods/labor myself and some of the paid labor I bartered/traded work(50-60%). Both of these cuts the cost down drastically. For me, it's the labor that adds up the quickest. If I had to pay for all of the labor, most of the mods on my Prius would never happen.
    When my work is slow, I get bored and work on my Prius, search for new mods/parts or work on our house. My next "major" project is replacing the deck, which runs on three sides of our home. :cautious: Beginning next week, my work begins to ramp up throughout the summer and early fall, and I won't have much time to add new mods or start new projects.
    This year, I get the chance to go back to The Quail:Motorsport Gathering for my work. Having a car that stands out in the parking lot(golf course) of that event is special.
    Trust me, mine will not be anything special in that crowd... :(
    ...but I'll try anyways. :rolleyes:
    ...as long as my gf gets the same budget for shopping/massages/etc, she's fine with it... :cool:
    ...besides, she thinks our Prius looks "cool"... (y)
    #208 sfprankster, Apr 9, 2015
    Johnsk93 likes this.
  9. lverasky
    lverasky New Member
  10. Boston Jim
    Boston Jim Active Member
    202
    148
    Hey @sfprankster, quick question for you, when you swapped out the license plate lights, is there any trick to getting the plastic housing out? I was able to swap one out of the lights, but it was very tough to twist it out, even locking it back in place took me awhile. I didn't have enough time tonight to get the other one in.
  11. sfprankster
    444
    490
    Did you remove the access panels in the rear hatch?
    Once the access panels(3" x 4") were out of the way, I just reached in and twisted them out CCW(counter clockwise).
    I don't remember them being very tight.
    Have you tried removing the lower rear hatch interior panel to get better access to them? Give you more room to work in. The rear hatch interior panel comes off easily with a little effort with a panel tool.
    Boston Jim likes this.
  12. Boston Jim
    202
    148
    Yep, pulled the access panel, spent quite awhile trying to get the first one out, gave up and tried the other side. I was able to get that one off finally and switched out, but still a very tight fit trying to get it back in. I haven't tried pulling the interior panel, but I may try that tomorrow. Thanks.
  13. Accordlayingkit
    1,618
    1,748
    377
    Before I switched to the full LED I remember having a problem turning mine as well. I ended up using a longer set of needle nose pliers to put on the bulb housing and turned just fine to remove.
    Or try doing more finger push-ups :rolleyes: lol
    #213 Accordlayingkit, Apr 15, 2015
  14. Boston Jim
    202
    148
    @Accordlayingkit I'll work on the one finger pushups :) I tried to use a small pair of needle nose pliers, gripping only the top portion of bulb housing, but it seemed like it was going to break it/twist just the top only. Today I had time and used a pair of regular pliers (though a bit narrow but not needle nose) and it came right out.
    I switched out the lights on my Prius v as well today and that was sooo much easier, no pliers required. But I did find some scorch marks on the bulb housing (bottom side) - doesn't look pretty on a 3 year old car. The original bulbs looked fine so I'm not sure what is going on, though when driving the Prius v I would just turn on the headlights all the time since it didn't have daytime running lights. Maybe having it on all the time was a bit much for those lights.
    #214 Boston Jim, Apr 16, 2015
  15. Jeremy Henry
    Jeremy Henry Junior Member
    MOSES LAKE
    Can you tell me where you got the window plug for the rear wiper motor delete.
  16. sfprankster
    444
    490
    I ordered it through Buyee.jp.
    When I get home on Tuesday, I'll PM you a link.
    I hate the autocorrect on my phone... :mad:
    #216 sfprankster, Apr 19, 2015
  17. Jeremy Henry
    MOSES LAKE
    Sounds great!
    note 3
  18. NoPistns
    NoPistns Junior Member
    @sfprankster ; This is all your fault!;)
    Mods to my 2015 Prius two as of today...
    Went "black wheel" a couple weeks ago. Looks pretty good with 2014 Corolla center caps. Pics to follow.
    Abused the plastic as follows: VLEDS are supplying the LED 5k low beam conversion; iJDToy for the LED interior lighting kit and license plate lamps; and AutoLumination (Automotive Household Truck Trailer RV Lighting Led Light Bulbs) for LED Backup 7440's and 194 parking lamp bulbs. Also bought a set of 4 silver stealth bulbs to replace the turn signal bulbs without the backache of changing out the flasher...
    #218 NoPistns, Apr 19, 2015
    sfprankster likes this.
  19. sfprankster
    444
    490
    I take no responsibility for any peer pressure that comes from reading any thread in the Accessories & Modifications topics... :censored:
    Besides, everyone here knows it's @Accordlayingkit's fault this week... :whistle:
    sfv41901, Jeremy Henry and Burna J like this.
  20. Accordlayingkit
    1,618
    1,748
    377
