Can Heated seat button be moved and actually fit
Discussion in 'Gen 3 Prius Accessories and Modifications' started by John Bergendahl, Apr 11, 2015.
  1. John Bergendahl
    102
    17
    gulfport,ms
    Wanting to know if this heated seat button(s) can be moved to this spot and has what looks to be a black cover.Is that black cover used for anything at all ? I want to free up the spot where the heated seat button is at to try and install a USB power option there...check pic
  2. frodoz737
    frodoz737 Top Wrench
    4,702
    2,501
    33
    I believe the blank you pictured is where the fancy variable cruse cruise button goes. I put my bass knob there. You can do what you asked if you feel comfortable removing panels, the console and relocating/stretching wires as required..
  3. John Bergendahl
    102
    17
    gulfport,ms
    Then i saw this too...Wonder if heated seat button can just go here to the right ... 20130517_43fda9.jpg 20130517_2d6966.jpg
  4. John Bergendahl
    102
    17
    gulfport,ms
  5. frodoz737
    4,702
    2,501
    33
    Looks like an option if you can find the part number/s needed. Same proviso stands. You could also just modify/cut your existing panel to mount your port/s.
  6. John Bergendahl
    102
    17
    gulfport,ms
    I wouldn't have put the fog light button right there like they did in that pic.But looks like heated seat button would go good there.I dont want to try cutting any plastic if i mess up and have to find a new one just to be a stage one all over again
  7. frodoz737
    4,702
    2,501
    33
    The options to you are only limited buy your resources and abilities. There are many posts where folks put USB and 3.5 jacks on that panel, or a blank on that panel. Take your time to research and check with the local car stereo installers for options as well. This is not a complicated mod. This is where I put mine, but would have put it on that lower panel if I had a do over.
    #7 frodoz737, Apr 11, 2015
    mertechperformance likes this.
  8. Tideland Prius
    16,559
    Actually it's for the Pre-Support function for the Intelligent Parking Assist (Advanced Guidance Parking System).
    Here's a photo with it installed.
  9. frodoz737
    4,702
    2,501
    33
  10. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    With a bit of creative wire routing it could be placed ANYWHERE.
