Pioneer NEX Anyone?
Discussion in 'Gen 3 Prius Audio and Electronics' started by bighouse, May 17, 2014.
  1. Toyonka
    Toyonka Junior Member
    75
    Thanks. My question was different, not related to steering controls. Please scroll up a couple of posts for my queries. Thanks in advance!
  2. Toddwilks
    Toddwilks Active Member
    555
    176
    Whitehouse Station, NJ
    1. Will the steering wheel controls be able to work with the pio unit for native pio control? Will they also function for CarPlay?
    Carplay is all Touchscreen, and yes, they will work for pioneer native control.
    2. Will the car information interface and info still be available for servicing?
    If you are talking about the screen on the radio that shows the car graph or the mpg graph then no. All other factory information is available.
    3. The pio unit has a hookup for a separate Sirius tuner. Will the xm tuner under my driver seat plug into and function?
    No. You will need the pioneer adapter.
    4. Will the backup camera still function?
    You will need to get an adapter for this to convert 12v from the radio to 6v for your camera.
    I really have scant love for the current JBL head unit. I know I would like the pio unit.
  3. Toyonka
    75
    OK, do you know if there is another way to access the vehicle settings page you presumably lose, like door lock beep volume, etc.
  4. Toddwilks
    555
    176
    The only way I am aware of is through the Toyota dealer tech star tool (i think thats what its called). There is an iPhone app that works over the OBDII port but I can't find the post again. Ill keep digging for it.
    Toyonka likes this.
  5. sfprankster
    sfprankster Active Member
    443
    490
    Santa Cruz Mountains, CA
    Have you tried an OBD II tool and the Carista app for Android or iPhone?
    Lots of info in the thread I linked if you do a little digging. It lets you customize settings and read and clear codes.
    myktek and Toyonka like this.
  6. Toddwilks
    555
    176
    That's the app!!! I knew someone would chime in. I couldn't find it while I was at work. I kept seeing dashcommander but I knew that wasn't it.
  7. Big Tex
    Big Tex New Member
    Does the voice command button get mapped to Siri if you use the steering wheel control adapter?
  8. Toyonka
    75
    Or Google?
    Thanks!
    "Recordar es vivir"
  9. mikedow
    mikedow Junior Member
    22
    West Palm Beach, Florida
    Apparently this is no longer true in 2017. Crutchfield sold me an adapter kit. I'll let you know how well it works out.
