What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    There's like 4 strut bars on the market for our car. They do virtually nothing as our strut towers are integrated into the firewall. I have the ultra racing brace. Looks cool when the hood is open I guess, but changed nothing.
    The darkened part of the front grill/bumper. Can be matte black or gloss. I think it looks best matte.
  2. Ecobill
    Ecobill Junior Member
    94
    Berea OH
    2014 Prius c
    Just added the Injen polished intake and a Spec D exhaust tip. Pics by tomorrow.
  3. mertechperformance
    532
    126
    Nor-caL
  4. yOsHi LiN
    yOsHi LiN Active Member
    215
    138
    los angeles
    2014 Prius c
    finally my friend brought this bak from china!!! i wish it was white !!!
    robbm3 and PLSPUSH like this.
  5. mertechperformance
    532
    126
    Nor-caL
    A little ricey but neat. Would also prefer white.
  6. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    yeah it is kinda ricey but there really nothin much to do to the C. just waitin for the lip kit now ...
    mertechperformance likes this.
  7. mertechperformance
    532
    126
    Nor-caL
    I'm waiting to get my airrex suspension and wheels. Other than that just black out the headlights and done. Might do the headlights first as it's not money dependant. Want the touring spoiler and hatch mid spoiler as well.
  8. tk1971
    tk1971 Active Member
    253
    133
    SG Valley, CA
    legoadan and PLSPUSH like this.
  9. SamanthaC0716
    SamanthaC0716 Active Member
    333
    115
    Did you have to get them cut by Toyota, or will anywhere that cuts keys do them? Do the unlock/lock buttons work, too?
    iPhone ?
  10. tk1971
    253
    133
    SG Valley, CA
    I cut them myself. I had access to a key machine last night.
    But I suppose anyone can do it (ie. Home Depot, Lowes, etc).
    One bit of advice: Remove the key blades from the cases before having someone cut them. The plastic case is bulky and didn't fit the Speedex machine I used. I can see where this can screw up aligning the blank with the original key and cause an issue. I've read that people have screwed up trying to cut these keys and I suspect this is why. Oh, and line up the key / blank at the tip, not the shoulder (no sharp shoulder on car keys, and the two don't match anyway).
    Having said that, I got 2 thinking that I might screw one up. Turns out I managed to cut both correctly.
  11. SamanthaC0716
    333
    115
    Thanks for the tips. This is very cool. I hate how 'standard' the key is. Are you able to use the lock/unlock buttons?
    iPhone ?
  12. tk1971
    253
    133
    SG Valley, CA
    The guts of my Toyota remote keys got moved to the new case, so yes, the lock/unlock buttons work. There's even a spot for the transponder chip if my car had one.
  13. Danger Dang
    Danger Dang New Member
    Houston
    2014 Prius c
    Nice work, now I am interested.. but damn that shipping time :/
  14. tk1971
    253
    133
    SG Valley, CA
    I was actually surprised that it took less than 2 weeks overall to get to me.
    PLSPUSH likes this.
  15. SamanthaC0716
    333
    115
    That's excellent. Ordering one now!
    iPhone ?
  16. mertechperformance
    532
    126
    Nor-caL
    Careful folks, the oem switchblade keys break often and these very cheap aftermarket ones will poetically break more easily.
  17. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    I have the same flip key. I have had mine since october. Got it from ebay for around $10. I drive the car and use the key everyday and the flip key is still in tact.
    I gave it to a shop to cut. They asked me to remove the key from the switch, so I did. My local homedepot and lowes said they do not cut keys that are not in their inventory. Meaning they would not cut the blank I had.
    I swapped over the buttons and it works well.
    If you have to remove the key blade from the switch, make sure you dont misplace the spring. I had to tighten my spring up when I reinstalled the blade so I could get a little more flip action from it.
    Otherwise, its working well. The sliver key ring part is pretty cheap and the paint comes off quickly.
    PLSPUSH and tk1971 like this.
  18. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    In the rear, I blacked out the emblem background, installed a receiver hitch, and installed the wiring pigtail for a trailer.
    In the front, I blacked out the emblem background, and in the lower section of the grill (below the bumper) I secured 1/4" screen to stop the majority of the rocks and pebbles that can damage the a/c condenser. Note: don't install too fine of screen, or it will overly restrict air flow.
  19. tk1971
    253
    133
    SG Valley, CA
    PlastiDipped the front bumper, added polished stainless beauty rings, chromed closed end lug nuts, and Mr. Gasket chrome caps.
    #459 tk1971, Apr 16, 2015
  20. deckbuild
    deckbuild Junior Member
    42
    Singapore
    The mesh is awesome, I got too many leafs stuck at my radiator now and it's bloody hard to clear them!
