hey guys,i need help with my prius.anyone who can help me please
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chichi hollywood, Apr 15, 2015.
  1. JC91006
    JC91006 Senior Member
    16,939
    8,647
    I'm going to take a stab in the dark here. Assuming this tech knows what he's doing with your car. He probably disconnected your HV battery. There's an orange service plug on your hv battery that needs to be locked in before your car starts.
    Put the orange service plug into the battery, tilt it up, and then PRESS DOWNWARD to lock it down. If the tech didn't press the orange plug downward to lock it, your car will not start.
  2. chichi hollywood
    chichi hollywood New Member
    lusaka zambia
    On the HV battery,i did check the orange service plug and it was just ok,locked in downwards
  3. bisco
    52,888
    you load the tech stream software on your laptop. this is specific to all toyota vehicles and what the dealers use. then you use the mini vci to connect the laptop to the obd II port under the steering wheel. it takes you through the process, and if the car has thrown any trouble codes, it takes you through a fault tree, drilling down to the specific problems.
  4. chichi hollywood
    lusaka zambia
    So the mini vci is just a connect that come with the software,or there different
  5. bisco
    52,888
    tech stream is the software, idk if they are sold together or separately.
  6. chichi hollywood
    lusaka zambia
    So i need the tech stream and a mini vci
  7. chichi hollywood
    lusaka zambia
    And can it also rest the system error codes,or it just scans the faults
  8. bisco
    52,888
    yes, you can reset as well. if thats all you want to do, you can get a simpler obd II reader like scan gauge II. it will read basic codes and reset.
  9. chichi hollywood
    lusaka zambia
    Ok thanks a million,let me try order via ebay,but will get back to you after three week or more because it the time it takes for it to get here.
  10. bisco
    52,888
    if you want to do more research, there a quite a few threads on it here. all the best!(y)
  11. chichi hollywood
    lusaka zambia
    Ok thanks,tho i just joined today so am not even sure were to find what,but will try look around
  12. bisco
    52,888
    use the search function in the upper right corner. try different key words and make sure you search all the forums.
  13. chichi hollywood
    lusaka zambia
    Oh ok, you've really been of help,thanks.
  14. Patrick Wong
    18,213
    6,530
    1. Is the new inverter coolant pump operating? Can you see fluid turbulence in the inverter coolant reservoir when you make the Prius IG-ON?
    2. If not, check the 15A AM2 fuse now. "Check" means that you measure continuity using an ohmmeter. Do not rely upon a visual inspection.
  15. chichi hollywood
    lusaka zambia
    yes the inverter is working because i can even feel the movement when its in IG-ON
  16. chichi hollywood
    lusaka zambia
    And also checked all the fuses and are all working corectly
  17. Patrick Wong
    18,213
    6,530
    Sounds like you need Mini VCI to obtain the diagnostic trouble codes. While you are waiting, put a charger on the 12V battery and make sure it is fully-charged - or if it won't hold a charge, get a new battery. The idea is to eliminate the 12V battery as a potential problem area.
    Also, check the fusible link assembly which is located in the main relay/fuse box next to the inverter. That assembly is around 5" long and has a clear plastic cover. Look into the assembly for any burnt fuse links. If you see any, the entire assembly will need to be replaced. Also if you see a burnt link, there is a good chance that the battery polarity was reversed when the car was jump started.
  18. chichi hollywood
    lusaka zambia
    ok i have to check on that fuse,and also get myself a new 12v battery
  19. chichi hollywood
    lusaka zambia
    and again how do i know its not the HV battery thats dead
  20. Patrick Wong
    18,213
    6,530
    You won't know one way or the other, until you are able to retrieve DTC logged by the hybrid vehicle ECU and traction battery ECU.
