2015 Prius v (lowercase v) Suspension vs 2014 Prius v Suspension
Discussion in 'Prius v Main Forum' started by Richard Immel, Apr 15, 2015.
  1. Richard Immel
    Richard Immel New Member
    Portland, OR
    2015 Prius v wagon
    I am thinking about buying a 2015 Prius v (lowercase v for the Prius v wagon) trim level 5. However, due to my wife's physical issues I need to be sure she can ride in the car without too much discomfort. So I have a 200 mile trip coming up and obviously that is too much mileage for "try before you buy" with a 2015 model from a dealer. However, I can rent a 2014 Prius v trim level [unknown]. So my question is, does anyone know if the the suspension between the two cars is radically different? Will the 2014 Prius v [any trim level] ride be equivalent to the 2015 trim 5 model?
  2. rjparker
    10,427
    6,531
    Trim 5 has lower profile tires so the ride might be a little harsher.
  3. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Maybe you should consider an Avalon Hybrid, gas mileage is excellent and the ride, quiet wmf comfort are several levels above the Prius family. If however you need room for things like wheelchairs the v (lowercase v for the Prius v wagon, as mentioned above) is a better choice. Also the price should be comparable.
  4. Richard Immel
    Portland, OR
    2015 Prius v wagon
    Thanks, we needed the storage so went for the Prius v. We are trading down from a mini van.
    That would certainly be the case if the suspensions were essentially the same.
  5. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    The 17" rims/tires are certainly a firm ride with great directional control and stability, but not "harsh"
  6. mikefocke
    4,039
    1,832
    Sanford, NC
    I've seen comparison books where a car manufacturer tells the sales force what changes/improvements they have made from model year to model year so the sales force can use them as selling points. Ask to see one.
    There may have been front suspension changes involved in the changes to meet the front offset crash tests. But have never seen any forum comments on noticeable by the driver differences.
    Tire pressure can influence the comfort level of the ride a great deal. A trade off of plushness against MPG. So if you rent, test the tire pressures before you go, know the tires and the tire size.
    As soon as you are back, try the car at the trim level you want to buy and do the same measurements and mentally compare the two even on a shorter ride. Dealers mostly do not inflate to optimum MPG but rather for a soft ride. You could even ask them to inflate the tires to the same settings if you wanted to. If they hesitate, mumble to the sales manager about ADA and reasonable accommodation.
    Wife has an Avalon, I prefer the v (lowercase v for the Prius v wagon as mentioned above), she doesn't.
  7. breakfast
    breakfast Active Member
    266
    199
    The years shouldn't matter. As rjparker said, Trim Level Five should have a firmer ride with the 17 inch tires.
    New for 2015, you may want to consider trim level Four for the Prius v wagon - that will have a softer ride with the 16 inch tires, plus it will have the softex, power driver's seat, etc. However, it won't have the active safety features that are available on the trim level 5 (radar cruise, pre-collision braking, etc.)
    For the 2014, there is no trim level four on the v - the highest trim level with the 16 inch tires is trim level three.
  8. rjparker
    10,427
    6,531
    If you compare also note the tire brands. Often a Michelin will ride better than a Goodyear or Bridgestone. But that difference is smaller than the feel of a low profile 17" versus a higher profile 16". The sidewall rubber vertical size increase of the 16" provides more flex in the overall suspension ride quality, much like an air ride spring uses it's rubber air spring to offer a close to optimum, dynamically adjustable ride on some luxury cars. Regardless, the Prius v rides better than most of the standard Prius models and certainly better than the earlier generation 2 Prius cars.
  9. BradW
    BradW Junior Member
    Redwood City, Ca
    2015 Prius v wagon
    I have a 2015 v (lowercase v for the Prius v wagon) My previous vehicle was a 2012 Nissan Leaf which I really enjoyed driving. I also own a Infiniti QX56 SUV which is super comfy but drives large. I can say my Prius rides far better then my Leaf. Its not harsh at all and is very comfortable. I drive with the Family on 120mile trips often and everyone is quite comfortable.
  10. Richard Immel
    Portland, OR
    2015 Prius v wagon
    I appreciate your reply, thanks.
    Thanks, we will be trying one out next month.
    "Management" wants the tech pkg available only on the trim 5, not sure how she will respond to all the audibles that go with that.
  11. mikefocke
    4,039
    1,832
    Sanford, NC
    I wonder if you bought the five and then offered a three owner to trade wheels and tires to get the 16s onto the five. Would have to be new tires and sensors but someone who wanted 17s might do that.
  12. Richard Immel
    Portland, OR
    2015 Prius v wagon
    That is a real creative idea.
  13. rjparker
    10,427
    6,531
    It would impact the speed readouts
  14. Richard Immel
    Portland, OR
    2015 Prius v wagon
    That could happen. I also wondered if the wheel bolt circle might be different, but probably not.
  15. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    ...and, if you don't want your wife to ride in your v, for a REALLY firm ride you can do as I did and swap out the OEM springs for lower and 5% stiffer Tanabe (or Cusco) springs. Better handling and only a bit stiffer ride.
    But then my handling mods including ENKIE RP F1 17" wheels and 5 model size 50 profile tires, 3 under-body braces, stiffer front sway bar and a strut tower brace. You'll have a lot more control if you have to make sudden evasive maneuvers.
