P0A78, P0A94, Inverter-Converter Unit issues 2006 Prius
Discussion in 'Gen 2 Prius Technical Discussion' started by RayW, Mar 9, 2015.
  1. RayW
    RayW New Member
    Eurkea, CA
    Have a rebuilt battery from a questionable source, as I asked about in an earlier thread, so when my wife told me the warning lights/icons came on again I was not particularly surprised- a notch or two beyond frustrated, yes- but not surprised.
    I was surprised when upon looking at the codes that came back through EngineLInk, I found they were not codes from the battery, but rather from the Inverter-Converter Unit.
    Have watched a few videos on the ICU, read a couple other threads, but am still uncertain how to proceed.
    I haven't found a clear and decisive meaning of the returned codes, so am uncertain if further detail is provided there, or if perhaps EngineLink can tell me more that I've not asked it to.
    I don't know how in depth the dealer would be, or if they will simply want to swap the entire ICU. Anyone have any experience along such lines?
    Much appreciate any assistance and/or suggestions.
    Ray~
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,449
    3,354
    Madison, Wisconsin
  3. abboomer
    abboomer New Member
    Minneapolis, MN
    Hey RayW, I'm experiencing the same codes. Could you tell me what you did to resolve your issues or any other information?
    We've experience shudders while driving, fail safe mode, warning lights...just trying to figure this out!
    Thanks!
    Piroxiljin likes this.
  4. bisco
    52,577
    how many miles on her?
  5. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    Check the inverter coolant. If it is gunked up it would overheat the inverter.
  6. abboomer
    abboomer New Member
    Minneapolis, MN
  7. abboomer
    abboomer New Member
    Minneapolis, MN
    Pump is on. Getting some turbulence in the reservoir. Any other tests I can do?
  8. bisco
    52,577
    you may need a toyota specific reader with troubleshooting tree. how long years/miles have you had her?
