Aftermarket suspension upgrade
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Nakamoto, Apr 19, 2015.
  1. Nakamoto
    Nakamoto Junior Member
    69
    Melbourne
    Greetings,
    I'm looking to upgrade my suspension to improve ride comfort over poorly maintained roads as it can sometimes get bumpy.
    As below, which of these represent good value and dramatically improve ride comfort?
    I keep my front wheels at 42 PSI and rear at 40 PSI - so that might explain the firmer ride, but I'm not looking to reduce the air pressure for economy reasons and if I can I hope the newer suspension would not lower the prius since i'm already scrapping the front bumper at my driveway if I'm not careful
    Toyota Prius 2010 ZVW30 Performance, Handling & Electronic Accessories :: Sigma Automotive
  2. Mike500
    Mike500 Senior Member
    2,593
    767
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I know of no such upgrades. All the suspension upgrades, I have seen, lower the car and firm-up the ride.
  4. BigBear2010
    BigBear2010 Member
    156
    65
    Megan with damper sets at 32 will soften the ride at least similar to stock if not more
  5. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
  6. Nakamoto
    69
    Melbourne
    hmm..I suppose these upgrades would lower the vehicle?
  7. cyclopathic
    3,292
    547
    2014 Prius c
    Tein will lower (0.9" at highest setting). KYB ExcelG are OEM replacements.
    I have replaced rear shocks with ExcelGs and it improved ride; they seem to swallow big hits much better than OEMs. OEM front struts are o'k, still on. And if you replace rear only no alignment needed, saves you another $100.
