2010 Prius Transaxle Failure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by js_nh, Apr 19, 2015.
  1. js_nh
    js_nh New Member
    Herkimer, NY
    I have a friend who has a 2010 Prius. She took the car into the dealership on Friday because of sounds coming from the under carriage and the diagnosis was a bad transaxle, apparently verified by metal shavings in the fluid. There doesn't seem to be any information online about Gen 3 transaxle failure. Is this common? I am a VW owner so I know all about shady dealerships. Could the dealership be mistaken about the diagnosis? She has about 160K miles on the vehicle and the estimated repair cost is about $5k.
    49,469
    yes, they could be mistaken. it's definitely worth getting a second opinion.
    you might also want to shop around for a salvage transaxle. it's fairly rare, so should be easy to find one. you just need a mech willing to install it.
    you should ask them for the codes the car through, not sure if metal shavings is the proper way to diagnose.
  3. Former Member 68813
    3,524
    981
    US
    well, even in this day and age sometimes there are no codes for mechanical failures. metal shavings and noise can be all there is. obviously there is no harm in second opinion and pricing used trans-axle.
  4. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    If she drove it there she can drive it somewhere else to have it checked....and you might want to go with her. At your age you know women are still taken advantage of in this industry.
  5. JC91006
    JC91006 Senior Member
    16,482
    8,399
    How many miles on the car?
  6. frodoz737
    4,297
    2,348
    33
    First post said 160K.
  7. JC91006
    16,482
    8,399
    At 160k miles, there could be a high possibility of transaxle failure. My 2005 had a failure at 150k. I would think the dealership has the DTCs to backup their diagnostic, just ask them.
  8. frodoz737
    4,297
    2,348
    33
    Yep...Toyota recommended lifetime ATF and brake fluid, 100K antifreeze and 10K oil...not for my car.
  9. Patrick Wong
    18,200
    6,474
    A few questions for your friend and the dealership service writer:
    What kind of sounds?
    What driveability symptoms are demonstrated other than these sounds? For example, any warning lights on, lack of power, etc.?
    What would happen if she just drained and replaced the transaxle ATF? How many more miles could she drive the car without having a failure?
    If it is determined that the transaxle must be replaced, then as previously suggested, a used unit would be the best way to go since the cost of a new transaxle is in four-digits.
  10. js_nh
    js_nh New Member
    Herkimer, NY
    Thanks for the responses!....JC- there are about 160K miles on the vehicle. Patrick- no engine lights and I don't think there has been any loss of power;as far as I know there is some rattling or murmur that sounds like it is coming from underneath the car at lower speeds.
  11. JC91006
    16,482
    8,399
    Murmur = whining sound when slowing?
  12. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    I hear some sounds beneath my car at around 15-20 mph during acceleration. It sounds like a vibrating piece of metal, such as a loose heat shield. The sound goes away at higher speeds. I haven't had a chance to poke around underneath the car yet, but plan to do so at the next oil change. I'll give an update if I find anything.
    As mentioned, get a second opinion.
  13. js_nh
    js_nh New Member
    Herkimer, NY
    Here is how my friend describes the noise:
    The noise only occurs when pressing the gas pedal. It is happening at the higher speeds also, but i can't hear it as well because of the road noise. The only other thing that seems to be occurring is a slight looseness in my steering wheel. The sound is like something is loose and vibrating against something else. If I press gas harder, the sound goes away.
  14. bisco
    49,469
    this could be absolutely nothing but a loose part such as rrxing mentioned. i would ignore it, or at most, have a mech put it on a lift for a look see. never heard of a bad tranny diagnosis without codes or drivability problems.
  15. Patrick Wong
    18,200
    6,474
    I suggest that your friend should have the transaxle ATF drained and replaced. Then she should just drive the car and not worry about this unless:
    1) she starts to notice driveability issues such as lack of power
    2) warning lights relating to the hybrid drivetrain appear
    3) the noise gets much worse. If the current noise level is muffled by road noise then it can't be very bad.
  16. js_nh
    js_nh New Member
    Herkimer, NY
    She has had the transaxle ATF drained and replaced as that was part of the dealer's diagnostic process. She is still driving the vehicle but reports the noise has gotten somewhat worse. She said it sounds like "grinding" and when she hears it getting louder she sort of babies the gas pedal until it normalizes. There are still no warning lights coming on. Assuming she will need to replace the transaxle soon does anyone have a recommendation for getting a salvaged transaxle? Is there some way to make a judgment about the long term reliability of a salvaged transaxle?
  17. Patrick Wong
    18,200
    6,474
    Regarding the purchase of a used transaxle, ideally you would select a low mileage donor, one that was hit in the back, not the front. If the transaxle did not suffer accident damage then it is a reasonable bet.
    There are no long-term guarantees of course, that is why a used part is relatively inexpensive to acquire. The salvage yard typically will offer a short guarantee - like a 30 day period - but the owner has to absorb labor costs, which typically will cost much more than the used part.
  18. frodoz737
    4,297
    2,348
    33
    Based only on what you have communicated, this noise could be any one of many other things...half shaft, wheel bearing, caliper/rotor, steering, loose hardware, ect... Any high cost repair quoted from a Dealership should be verified, especially when given to a woman who does not know cars. This rule of life applies in NY too. ;)
    Have you gone with her to another shop for that second opinion yet. This is what you need to do "first" if you want to help your friend.
  19. js_nh
    js_nh New Member
    Herkimer, NY
    frodoz-I am in another state and she has an extremely challenging work schedule so has not had the opportunity to get a second opinion. I will certainly make sure she sees all the great commentary. Thanks.
  20. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    What specifically was that "diagnostic process"? Did it unambiguously indicate trouble in the transmission? Did extraordinary amounts of metallic particles exit with the old ATF?
