2015 Consumer Reports survey
Discussion in 'Gen 3 Prius Main Forum' started by hlunde, Apr 20, 2015.
  1. hlunde
    hlunde Member
    419
    75
    I just completed my annual Consumer Reports survey and included feedback on my 2010 Prius. While completing the survey, I was asked specifically about oil consumption and performance of my vehicle in snow. The oil-consumption question seemed very unusual for a general survey and I'm wondering if these survey questions were in some way tailored for a Prius (or Toyota)? I did respond favorably about my Prius so I'm quite sure that these odd questions were not follow-up to some other response. So, has anyone competed this survey for a different vehicle?
  2. Mike500
    Mike500 Senior Member
    2,593
    767
    do not know. I noticed the same when I did the survey on my 2012 "v" wagon.
    I noticed that they emailed the survey to me as a former subscriber.
    I guess they are after a larger representative sample and wider demographic.
    #2 Mike500, Apr 20, 2015
  3. JC91006
    JC91006 Senior Member
    16,815
    8,596
    There are lots of concerns about oil consumption on the Prius. The survey probably wanted to address that issue.
  4. Mendel Leisk
    41,833
    FWIW, this is the first car we've had that seems to consume zero oil between changes, at least so far, a bit over 50,000 km's.
  5. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I have not had any that uses oil since I have been driving Nissan, Honda, Lexus, Mazda, and Toyota. My three Kubotas don't use any oil either. My 38 yr old Italian Acme uses a little oil so I have to check that before each use.
  6. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    I was asked about oil consumption on both my cars (Prius & Odyssey), so I don't think it is specific to the car. As a market researcher, the data would not be meaningful if it was only asked for one particular make/model.
  7. Virg
    Virg Junior Member
    28
    Austin Texas
    I have a 2014 Prius3 and a 2015 Mazda 3. No oil consumption for either. I have not had a modern car that consumed oil since my 1952 Chevy Bel Air. It consumed one quart per thousand miles which was normal at the time.
    Virg
  8. Former Member 68813
    3,524
    983
    US
    relax, the consumption issue doesn't start in toyotas until 70,000-90,000 miles.
  9. Former Member 68813
    3,524
    983
    US
    same now per the owner manual.
  10. Mendel Leisk
    41,833
    And then I can say: Finally! :ROFLMAO:
  11. tv4fish
    tv4fish Member
    202
    46
    Really - Any documentation to support that?
  12. KenSoren
    KenSoren Junior Member
    31
    Yucaipa, CA
    I know there is a problem with some Camry's 2007 to 2009 models. We just got an extended warranty letter on our '09 TCH covering it for 10 years or 150,000 miles. So far it has 75,000 miles and it uses a little over a quart in 5,000 miles, so hopefully it doesn't get worse as it ages.
    The Prius has almost 8,000 miles on it and had the oil changed at 5,000 miles. I will be getting oil changes every 10,000 miles in the future. So far no indication of any oil use - knock on wood.
  13. JC91006
    16,815
    8,596
    unless you've been hiding under a cave, this is a known fact.
  14. tv4fish
    tv4fish Member
    202
    46
  15. JC91006
    16,815
    8,596
    There are many reports of the oil burning issues, whether they are actual "facts" I wouldn't know. I own 4 priis and all 4 burn oil. So based on that, I'm at 100% based on my experience with my own cars.
    If your car is not burning oil, great. Many on here don't have issues. I must have 4 defective cars.
  16. Okinawa
    Okinawa Senior Member
    1,333
    320
    Probably not too much then.
  17. Former Member 68813
    3,524
    983
    US
    you really have to tell us all you do to your cars. it's very important to know it, so we would just the opposite.
  18. JC91006
    16,815
    8,596
    Basically I just drive it. So to avoid the oil burning issue, I guess you would have to not drive it.
  19. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Our 2007 has 160+K miles and our 2011 has 80K+ miles. No oil consumption on either. BTW I changed the 2007 to synthetic (Mobil 1) around 100K miles.
  20. fuzzy1
    10,594
    Same here, with two newer cars in the household (Prius & Forester), it asked about oil consumption on both.
