Check your Cabin Air Filter Today!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, May 5, 2006.
  1. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    its rare that you can visually assess the remaining effectiveness of the filter. very fine particulates can clog it, reducing air flow which reduces the effectiveness of the HVAC
  2. Mendel Leisk
    41,933
    Good point. Maybe I should cave and change, D.O. for engine filter.
  3. bisco
    52,408
    true, but greg0764 seemed to be implying that he removed his permanently?
  4. bisco
    52,408
    same with mine and the air filter, never more than a slight grey color.
  5. Mendel Leisk
    41,933
    Yeah forget my last post, I'm never gonna change it.
  6. bisco
    52,408
    one less hurdle in life.:p
  7. Intimate
    Intimate New Member
    22
    Pensacola
    Good lord. Nothing like an explosion of leaves in your face.
    Ok. slight exaggeration.
  8. bisco
    52,408
  9. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I checked mine. It was a little dirty, so I blew out the debris with compressed air. Then dunked it in a bucket of water with capful of Woolite detergent. Rinsed, then blew it dry with compressed air.
    Looked like new.
    Re-installed.
  10. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    The dealer wanted to do it on the last service but I'm glad I looked here first. I'm normally a guy who has a dealer or mechanic do just about everything on a car but this task was just way too easy to pay someone else to do it. $18.99 for the Fram Fresh Breeze at Pep Boys, less than 5 minutes of my time with no tools needed and it was done.
    The old filter had picked up a lot of leaves and dirt since it was changed 13,000 miles ago but I'll try to clean it up and then I can just rotate filters as needed for the next few years.
    One question: The piston in the glove compartment assembly was missing. The glove box doesn't rattle or seem to have any negatives without it. Is it really necessary to replace it or am I okay without it?
  11. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …I've noticed in my 2009 Gen II, that sometimes the "piston" retainer moves to a position so that it's difficult to see, are you sure that yours isn't just playing "hide & seek"??
  12. srellim234
    1,201
    1,694
    Laughlin, Nevada
    I looked with a flashlight and felt around for it and didn't find it. I'll check again later this morning. Whether I find it or not, is it really necessary?
  13. WilDavis
    2,493
    2,155
    49
    Once the glove box is latched in position, not really, it;s function is to prevent the box from dropping too far when unlatched.
  14. srellim234
    1,201
    1,694
    Laughlin, Nevada
    With all the different storage areas in the car I rarely open it anyway. If it's not there I won't sweat looking to replace it.
    Thank you for the reply.
  15. Mendel Leisk
    41,933
    Without that piston the box flops open with no damping?
    ETP likes this.
  16. srellim234
    1,201
    1,694
    Laughlin, Nevada
    That's why I was asking. When I've opened mine the box rests in a normal "open" position, resting on the top clips (the ones that have to be pushed towards the center to remove the box entirely). I don't know that the piston makes any difference in glovebox operation. I do see that if you're not careful the piston will keep the box from dropping on your toes while detaching it.
    ETP and Mendel Leisk like this.
  17. Mendel Leisk
    41,933
    Does it it drop open with no damping then? I guess it would.
    ETP likes this.
  18. srellim234
    1,201
    1,694
    Laughlin, Nevada
    No damping but we usually don't let the box just flop open anyway. We usually ease it open to avoid that issue.
  19. Okinawa
    Okinawa Senior Member
    1,333
    320
    It is not necessary if you hold on to the door and let it own slowly when you open it.
    srellim234 and ETP like this.
  20. ETP
    2,803
    1,170
    Auburdale FL
    First time I changed mine on a Gen 2 I broke something. Can't remember what it was but never fixed it.
