Spontaneous door unlock, triangle warning light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wmcbrine, Apr 19, 2015.
  1. wmcbrine
    wmcbrine Junior Member
    56
    Laurel, MD
    A weird thing happened to me just now in my 2005 Prius -- several times, while driving, the doors spontaneously came unlocked, while the red triangle with the exclamation point flashed on the dashboard. I was able each time to relock the doors from the master switch, and nothing else seemed to happen. At first, I thought I might be accidentally hitting a button on the key in my pocket, but I couldn't reproduce the effect by intentionally hitting the buttons. I stopped at my destination (Home Depot) and hoped the problem would go away as suddenly as it appeared, but it happened again on the way back.
    I have SKS. The key is a relatively new one that I had made some time after I got the car in 2010 (so 2011, maybe?). Any ideas?
  2. wmcbrine
    56
    Laurel, MD
    I took it into the dealer this morning. They want to replace the shifter, and possibly the battery (they said they can't test it properly until the shifter's replaced). ~$1000 total. :(
    The symptoms actually had changed for the worse -- now, it put up a notice saying something like "Caution: Put the car in Park. The batteries won't charge in Neutral." Meanwhile it's in Drive the whole time, still actually driving fine mind you. But the red triangle and warning beep were continuous. Then, when the dealer tried the car, the error didn't happen, until an hour or so in (they did the steering column recall first).
    #2 wmcbrine, Apr 21, 2015
  3. JC91006
    JC91006 Senior Member
    16,827
    8,600
    If your 12v battery is questionable, you should replace that first. I believe that's the source of many of the things you're seeing. After you replace the battery, you'll have a better idea what's actually wrong.
    Eclipse1701d likes this.
  4. bisco
    52,354
    you can get a used shifter for cheap. is there someone you can take it to besides toyota?
  5. Yakoma
    Yakoma Active Member
    470
    125
    sss
    The stealership is trying to take your money. They can't diagnose until the shifter's been replaced? LOL...the exact opposite is true. I'd start with the cheaper option (12v battery) first. And you can do that yourself. These damn stealerships are slimeballs.
    As you would see if you search here, weird crap happens when the 12v battery is marginal. I concur with JC above.
  6. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I've experienced the triangle and that display message when the drivers' door isn't closed properly and the shifter is in gear (as irrelevant as it seems). Double check to make sure nothing is in the way of the drivers' door closure, the door seal is properly in place and the striker is aligned. If it is in fact closing properly, maybe the drivers' door closure switch or its connection is getting temperamental. I suppose that could cause odd behavior with the locks too.
    #6 tanglefoot, Apr 21, 2015
  7. wmcbrine
    56
    Laurel, MD
    More of the story...
    They called me the next day to say they'd replaced the shifter (~$750), and "good news", the battery was OK, and didn't need replacing. (They included the printout from the battery tester in the papers they gave me, and it rated the battery health as "very good".) So, I went to pick it up, and... immediately, it was doing the same thing. I go in and tell them, the mechanic happens to be there, and we go back to the car together. Everything works perfectly. At this point, he suspects the door latch sensor... but we try and try to get the problem to surface, with no effect, except (the mechanic says -- I didn't see it) one brief flash of the "door open" light. So, I leave the car with them overnight for more testing.
    The next day... they couldn't reproduce it, so they're giving up. I decide to leave it for the night, and pick it up this morning. I get there, and immediately, it's doing the same thing. So, this being Carmax Laurel Toyota, I head to the sales desk and get them to appraise it. The appraiser, of course, finds nothing wrong. As I head home, there are only a few brief moments of weirdness on the return trip, mostly at the start, but also a couple times turning corners.
    I'm beginning to wonder if part of the issue is my weight. I'm a heavy guy, probably heavier than anyone Carmax had driving it. And, when I had the mechanic as a passenger, that weighed down the other side of the car, so it was more balanced. Am I totally off base with this idea?
    BTW, although I knew it wasn't the problem, I can't honestly say that there was nothing wrong with the shifter -- it had been a little sticky ever since I got the car, not enough to be an issue, but just enough to notice. It works better now. So, I can't say that the repair had no value, even though it didn't solve my problem.
  8. wmcbrine
    56
    Laurel, MD
    I wish I knew a place. Back when I got the car, I didn't know of any local shops that I could trust with a Prius. But seeing how many Prii are around now (three others just on my block!), there must be some demand for independent service. I haven't needed much, but I've been generally pleased with Carmax Laurel Toyota, but they aren't cheap.
  9. JC91006
    16,827
    8,600
    Has this car ever been in an accident? This could be a wiring issue
  10. wmcbrine
    56
    Laurel, MD
    Not in the time I've had it (five years). Before that, I think so, but I don't know any details, except that a side mirror was replaced IIRC.
  11. JC91006
    16,827
    8,600
    Is your car a salvage title or rebuilt title car?
  12. wmcbrine
    56
    Laurel, MD
  13. JC91006
    16,827
    8,600
    Did Toyota check to see if there were any DTC codes in the car?
  14. wmcbrine
    56
    Laurel, MD
    They said that nothing showed up. :shrug:
  15. JC91006
    16,827
    8,600
    sounds like a loose wire somewhere. HOw's the carmax appraisal?
  16. tpirsig
    tpirsig Junior Member
    Set up a gopro and film it happening?
  17. wmcbrine
    56
    Laurel, MD
    $5000. Within what KBB.com tells me to expect, albeit towards the low side.
    It kills me to think of leaving this car, but I guess that's where I'm at right now. I feel like I was just getting to know it, after five years. But it's probably entering the age of more frequent breakdowns... :(
    I did already half-heartedly try recording it with my iPad, but couldn't make that work.
  18. bisco
    52,354
    you might try leaving it there, go in the morning with the service manager, have him watch from outside while you sit in it and see if it happens. i would want my money back if i could show them.
  19. wmcbrine
    56
    Laurel, MD
    Farewell, old friend. You were a great car for five years, but then you went crazy. You're CarMax's problem now.
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Well you identified a problem, and utilized a solution.
    What replacement vehicle are you considering?
