After market satellite radio connection
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by GTE, Apr 22, 2015.
  1. GTE
    GTE Junior Member
    I have a 2015 Plug in Prius and want to use my Starmate 8 ala carte radio in my Prius. I need an audio or aux input which the Prius does not seem to have.. It does have a USB input which works with my phone and iPad but will it work as an input for the satellite radio? If it will I need an audio plug to USB to connect. Any ideas if such a connector exists. It can be either a male or female audio connector.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    you would need some way to convert audio to a data stream because USB only has a 5 volt dc power connection as well as a + data and a -data connection, ( no audio)
    USB - Wikipedia, the free encyclopedia
  3. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    There should be a 1/8" female jack located next to the USB Aux in. You will need a stereo cable with a male 1/8" mini jack on each end. Best Buy or Radio Shack carry them.
  4. srl99
    srl99 Member
    113
    2014 Prius Plug-in
    if the starmate is a sat radio, wouldn't it be better to just move the subscription to the PiP ?
  5. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Afaik, there is an auxin put in the center compartment box, next to the usb input, what year is your car?
  6. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    The Pip Comes standard with sat radio, just have to activate it
  7. GTE
    GTE Junior Member
  8. GTE
    GTE Junior Member
    The ala carte plan lets me select 50 channels and is cheaper
  9. GTE
    GTE Junior Member
    Ala carte is cheaper and better
  10. GTE
    GTE Junior Member
    It is cheaper and can move car to car
  11. GTE
    GTE Junior Member
    Thanks to all!!! I found the 3.5 mm audio jack. Toyota buried it under the USB so any user would have trouble finding it. My Starmate 8 satellite radio works just fine through the plug. I had asked about using the USB during a service visit and they said no, but they did not refer me to this plug.
