Oil Change 2014 Model Two
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Noodleho, Apr 26, 2015.
  1. Noodleho
    Noodleho Junior Member
    32
    Sacramento
    This will be my first oil change on my own. Can anyone tell me how many Quarts does this model take? Thanks.
    52,351
    how many different answers would you like?:p
    Noodleho and xliderider like this.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    It's somewhere between 4 and 5 qts. I bought a 5 qt jug of 0W-20, and tried to fill with 4 qts by eyeballing the level in the jug. It took mine to the middle of the range on the dipstick.
    Noodleho likes this.
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    About 4.25 qts with filter change .
  5. Mendel Leisk
    41,865
    With filter change, 4.4 US quarts (4.2 liters) will put the oil level on the top mark on the dipstick. The drain bolt requires a 14 mm socket (torque is 27 lb/ft). The oil filter housing requires a 64.0 mm 14 face socket (torque is 18 lb/ft).
    JamesKFChiu and Noodleho like this.
  6. Noodleho
    32
    Sacramento
    Thanks all.
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I use 4 quarts with filter change and it puts it in the middle of the two dimples on the dipstick.
  8. JamesKFChiu
    JamesKFChiu Member
    95
    52
    ORANGE
    Thanks a lot for sharing this information! Sad enough, many shops don't care about torque anymore…
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    Also, don't assume they put the proper amount of oil in the car either. I gave the dealer a 5qt jug and didn't get any oil or container back, and the oil was overfilled. :rolleyes:
  10. Mendel Leisk
    41,865
    There's a lot of instruction in my attachment regarding position of stiffeners on the oil filter housing, and the retention clip. You can ignore it, it's pointless.
  11. KenSoren
    KenSoren Junior Member
    31
    Yucaipa, CA
    What I have always done is buy a 5 quart jug of Mobile One and pour out 2 cups into an old measuring cup. Then you can add the whole container without trying to eyeball anything. After you empty the container then pour the half quart back into it and save it incase you need to add oil during the next 10,000 miles or one year.
  12. qdllc
    qdllc Senior Member
    1,377
    400
    Or just buy 5 one-quart containers and only put in 1/2 of the 5th bottle. :D
