Battery not charging fully when driving?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NickInNJ, Apr 27, 2015.
  1. fuzzy1
    10,406
    The gasoline engine won't fill it, but downhill regenerative braking will fill it.
    NickInNJ likes this.
  2. ITgem679
    ITgem679 Junior Member
    73
    17
    I have not encountered a hill to test this. In the coming weeks, perhaps I will and then I will be able to see if that happens. However, in the month I've had my Prius, I have not.
  3. Mendel Leisk
    41,317
    If your battery's typically around 50% that seems a bit low, at least: ours is usually around 75%. Maybe it just varies, but my hunch is you're pursuing ev a bit too aggressively.
    If ours is around 50% it's usually on its way down, or climbing back. It's not typical status quo.
  4. CR94
    CR94 Senior Member
    2,687
    1,166
    Northwestern S.C.
    I agree with Mendel's post #23.
    Bisco, what I meant about "mostly" normal was that the 50% claim wasn't quite normal, as Mendel and others have elaborated.
    My state-of-charge display spends roughly 90% of its time showing six bars, only going higher on large downhills, and only going lower when the engine is not running. I was initially surprised it didn't drop below six bars on large uphills, but it doesn't, as long as the engine is running.
  5. bisco
    51,840
    mine will also fill on the highway, under the right conditions, no braking.
  6. NickInNJ
    NickInNJ Junior Member
    61
    New Jersey
    i was able to get 41 mph. :)
  7. bisco
    51,840
  8. NickInNJ
    61
    New Jersey
    You guys are right, I am probably trying to use the EV mode to often :)
  9. bisco
    51,840
    yes, you're supposed to not use ev mode when hypermiling.
  10. NickInNJ
    61
    New Jersey
    i use it not knowingly, i don't press any mode's , just drive within the speed limit..i try to accelerate smoothly as possible in city/town driving under 40 mph so it run's on ev mode only, unless i get a tailgater behind me
  11. bisco
    51,840
    ya, there are some speeds where ev is hard to avoid. thats where pulse and glide comes in.
  12. NickInNJ
    61
    New Jersey
    pulse and glide, is then accelerate and gliding till is slow's down naturally and speed up again? sorry it's my 1st prius
  13. bisco
    51,840
    yes, accelerate moderately, (slightly right of the mid line on the hsi) then release pedal and apply enough pressure so that you're gliding (no ev or regen) it's hard to glide, so a little ev just right of the line is fine.
    you have to be in an area where you can pulse a little higher than the speed limit, and glide to a little lower, without driving the guy behind you crazy. rinse and repeat.
  14. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    It's easier to control pulse and glide if you select "eco mode". The modes mostly just modify the throttle response rate, and "eco mode" gives the largest throttle pedal movement at lower power.
    I don't think there is anything wrong with your car. If you want to maximize fuel efficiency (it's a hobby) it takes lots of practice.
    I don't think you should concentrate so much on that just yet. First get used to the car, and how it reacts to what you do. Read some of the things on this and other forums on the use of pulse and glide and try some of them out. It's not rocket science, you'll get used to doing it all the time and your mileage will improve to the 60s range when you get good at it. Much lower in winter, of course. ;)
  15. Mendel Leisk
    41,317
    One thing I've noticed: driving with car warmed up, roads relatively level, lower city speeds, if you set Cruise Control: the car will happily stay in EV, keeping the HSI (bar indicator) to the left of median, but right up to the threshold, as long a possible.
    If there's no interruptions, it'll quickly run the state of charge right down to two bars remaining, no qualms.
  16. NickInNJ
    61
    New Jersey
    I don't understand the Eco button, I find it harder to accelerate than regular mode.. is it me, but pick up is much faster in regular mode, i drove in regular mode to work and I got areading of fuel consumption of 65.9 , i drove home in the ECO mode back yesterday I got 48.3 mpg fuel consumption, same speed an everything. I don't use cruise control since i'm learning to ease of the gas pedal and coasting and speed up to normal speeds :)
  17. fuzzy1
    10,406
    Nothing in the propulsion system changes. Those mode buttons change only the user interface (throttle mapping of the gas pedal), plus some relatively minor tweaks to the AC and cruise control function.
    So, it is just you, and how you relate to that user interface (i.e. gas pedal). The choice boils down to personal preference more than anything else. Clumsy people like me should usually get a bit better mpg in ECO, while people with the best coordination and dexterity should be able to get the same mpg in every mode.
    The way the mode buttons relate to your foot on the pedal should change MPG by somewhere between zero and a few mpg, in either direction, depending on your particular driving style. The large change you witnessed was caused by something else.
    Is your workplace at a different elevation than your home? That can make a big difference. Did wind or weather change? Did traffic density or behavior change?
    Tomorrow, reverse the pattern, use ECO to work and Normal to home. See if the pattern stays the same or inverts. After that, use the same mode for full round trips, but change modes for different days.
    #37 fuzzy1, Apr 29, 2015
  18. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    ECO mode adjusts the throttle response, among other things, so it will feel more sluggish. However, I doubt that was the "sole" reason for the mpg difference. I can get 70+ coming back from the library (about 7 miles), but only get high 40's/low 50's going, and that's with the ICE already warm. The next trip, similar traffic pattern, I won't came close to 70. The best way to compare is to drive it R/T in both modes for several days each and average the mpg. Even then there might be unseen factors at play, longer time to get up to speed, longer stop at traffic lights, less coasting time, etc., any number of things, especially on short trips.
  19. NickInNJ
    61
    New Jersey
    I got those number on a 45 mile commute each way..
  20. CR94
    CR94 Senior Member
    2,687
    1,166
    Northwestern S.C.
    If you push the accelerator appropriately farther down in "ECO," then "pick up," fuel consumption, and what the HSI indicator bar shows will be all exactly the same. The main difference is that "ECO" makes it easier to fine-tune light acceleration. You also get to exercise your leg muscles a little more, to achieve the same results.
