What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. xliderider
    xliderider Senior Member
    8,057
    3,224
    Honolulu, HI
    Not as weird as that tail pipe! :eek:
    mertechperformance likes this.
  2. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
  3. mertechperformance
    532
    126
    Nor-caL
    So today I plasti dipped part of my front bumper and rear hatch handle. Here's some crappy pics....[​IMG][​IMG]
    in process
    [​IMG] better lines [​IMG]
    I did the hubcaps as well but might leave them off, should be getting rpf1's soon anyways.
    yOsHi LiN likes this.
  4. mertechperformance
    532
    126
    Nor-caL
    Kind of just how I roll.
  5. mertechperformance
    532
    126
    Nor-caL
    Baked the headlights and went for it. Blacked out some stuff behind the bumper as well. NOT the radiators and coolers though.
    Another shot [​IMG]
  6. chriswong
    chriswong New Member
    Help install fog (w/ DRL) & corner lamps for my friend today!
  7. mertechperformance
    532
    126
    Nor-caL
    Some up close yet still crappy pics
    [​IMG] i'm pretty happy with the results. I'd say they're 8.5-9.0 out of 10 or so. Stoked I didn't really f**k anything up.
  8. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    It's sound deadening time. My 120 sq' of MurderMat had arrived. I started with the rear hatch, then the doors, and finally the interior. I applied MurderMat on both panels of the doors, inner and outer. I was very meticulous about covering as much as reasonably possible, and because of the generous thickness of the deadener, only needed a single layer. I had enough to cover everything except for under the rear seat and battery area, and rear seat foot area. About another 16 sq' would be needed for this. The butyl MurderMat was quite easy to apply and to work with. I highly recommend it.
    The hatch is stripped down and ready to start.
    sd1.jpg h
    Finished inner panel. The 4 side doors were finished the same way, covering both inner and outer panels.
    To remove the headliner, the rest of the interior needed to be removed.
    And there it is, all neatly stacked after removal.
    This is the roof. The pic was taken with camera positioned by the dash, looking upwards and to the rear. The black bar at the top is the rear support bar for the sunroof.
    Almost finished...
    Front area.
    This was taken from the front seating area, looking into the rear seating and battery area. I was unable to apply deadening because I ran out of material. I figure that 16 more feet would have been needed.
    And yes, it is all reassembled and everything works fine. (Whew!!!)
  9. Motov8r
    Motov8r Member
    102
    How difficult is the headliner to remove? Any tips? Thanks.
  10. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    Overall, it wasn't too bad. The most challenging things were disconnecting some of the electrical connections, and the removal of some of the components that hold the headliner in place. Several fasteners have a unique way for removal. The plastic coverings from the kick panels (located at each door, just above the carpet), all the way up to the headliner need to be removed. The dash stays untouched.
    My best tip is that I used an online coupon for a 2 year subscription with Alldatadiy for $12.95. I referred to it quite a bit. It also helped that I have former experience working on Toyotas.
    chriswong likes this.
  11. SamanthaC0716
    SamanthaC0716 Active Member
    333
    115
    My brother painted the inside of my headlights.
    iPhone ?
  12. SamanthaC0716
    333
    115
    And we added SickSpeed horns! Big improvement over stock horns. Way louder.
    iPhone ?
    PLSPUSH likes this.
  13. Ecobill
    Ecobill Junior Member
    94
    Berea OH
    2014 Prius c
    image.jpg image.jpg image.jpg image.jpg I added a sick speed shift knob, Aries 3d floor inserts and an aluminum strut brace.
    Blindhopes likes this.
  14. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    Awesome brother!
    What's that Amber lens on high beam and how did you just paint the chrome part of front emblem?
    Looks great!
  15. xliderider
    8,057
    3,224
    Honolulu, HI
    I thought it's reflecting the yellow color from a yellow highbeam bulb. But I see now he has an LED bulb in there. So it's reflecting the yellow color from the LEDs, or there is possibly a coating of clear yellow tint sprayed on the highbeam reflector. The cover is still clear.
  16. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    Looks yellow tint on the high beam reflector.
    Effect is very cool!
    And I'm guessing the front bumper come off to remove the headlight housings...
  17. Danger Dang
    Danger Dang New Member
    Houston
    2014 Prius c
    Is there a guide somewhere on how to do this process?
  18. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
  19. SamanthaC0716
    333
    115
    Thanks!
    It's yellow chrome paint on the inside of headlights. My brother paints headlights, so he did them for me. He has a WRX and did his that way, and I liked the look.
    As far as the emblem, it's black Plasti Dip.
    iPhone ?
  20. SamanthaC0716
    333
    115
    Bulb inside is LED but produces no yellow effect. Good eye. Haha. That part of the headlight is painted with yellow chrome paint.
    The front bumper was completely removed to pull the headlights.
    Sem my iPho
