Back door won't open
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by David B., Apr 29, 2015.
  1. David B.
    David B. Junior Member
    Grand Junction,CO.
    back door my 2007 prius Wont open I've opened it with the manual latch from the inside underneath in the luggage compartment and reset the power locks but it doesn't make any difference I still can't open the door from the outside has anyone else had this problem
    49,734
    welcome! search for 'latch or hatch lock mechanism'. iirc there is a thread with repair/replacement instructions. by 'patrick wong' maybe? all the best.
    #2 bisco, Apr 29, 2015
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    is your hatch handle cover turning into goo? some of the handle covers were made of defective rubber and they turn gooey and can jam up the micro switch in the handle.
  4. David B.
    Grand Junction,CO.
    it does seem soft ill check it out thanks.
  5. David B.
    Grand Junction,CO.
    thanks ill check it out.
