2002 Prius ICE won't start after oil/ATF fluid change
Discussion in 'Generation 1 Prius Discussion' started by romanlutsk, May 1, 2015.
  1. romanlutsk
    romanlutsk Junior Member
    73
    Cupertino, CA
    2002 Prius
    After dreaming of owning a hybrid for quite some time, I finally picked up a 2002 prius with 62K miles. Bought a few weeks ago from a neighbor, where it was sitting undriven for 2-3 years. The original 12v battery was pretty weak (would only hold charge for 12 hours), but the hybrid battery seemed ok (no more ECU errors after letting the engine charge it for some time).
    So, it drove great for a few weeks, but this morning the ICE wouldn't start.
    The dashboard now has the following lights (it was all fine before)
    low oil pressure light
    hot coolant light
    check engine light
    car with exclamation point sign
    Turtle sign
    The diagnostics so far:
    1) Standard ELM327 ODB2 Bluetooth scanner says that there are no codes stored in the ECU
    2) oil dipstick shows oil almost to the top marker
    3) inverter fluid shows a little movement (barely noticeable) when the car is on
    Oil and oil filter were changed 3 days ago on Monday night. I used a mixture of about 1/4 quart of Mobil Super 5W-30 Conventional Motor Oil (fresh from the store), 1 quart of 10w-30 Pennzoil and 1.5 quarts of 10w-40 SuperTech 10W40 Motor Oil (both probably around 5 years, got from the previous owner)
    ATF fluid was changed on Wed night 1 day ago. I used Toyota ATF Type T-IV (also probably around 5 years, got from the previous owner), 2.5 quarts, simple drain and fill.
    What I tried so far:
    1) another battery/jump-starting - same result
    2) disconnected the battery for 10 min to reset the ECU - to no avail
    I thinking the possible culprits could be:
    - clogged oil filter
    - broken oil pressure sensor
    - broken oil pump
    - broken/stuck thermostat
    - broken coolant temperature sensor
    - wrong oil type (1x10w-30 and 3x10w-40 instead of recommended 5W-30)
    - air in the oil pump
    Could anyone suggest what I should check for next?
    Also, where I can borrow a hybrid-friendly ODB2 scanner/diagnostic tool around San Jose airport (San Francisco (South) Bay Area in California). Any friendly prius owners with a good scanner in the area?
    Thanks a lot!
  2. shagpal
    shagpal Junior Member
    you definitely have wrong viscosity oil. I had this issue too, but I thinned down my oil..
    I would put in on equart of 0w-20 or 0w-30 and top it off with 5w-20 to the bottom line first, then add to half the stick after you get it started. do not top off to the top line of the stick.
    spray the MAF and throttle body down with some cleaner, make sure TB is not sticking.
    clear the codes, then try to starting again.
  3. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Thanks. Just spoke to the previous owner and he swears that 10w-30 is what's recommended in the maintenance book he has and that's all he used before. The 2002 prius manual says 10w-30 is ok for the temperature range 0 to 100F, so I'm not sure how it could cause the "low oil pressure light". Perhaps the oil pressure sensor is faulty - any way to check that?
    The strange thing is that the ECU wouldn't even attempt to start the engine. Perhaps there is some type of electronic/electric fault somewhere?
  4. Patrick Wong
    18,210
    6,513
    A few questions/comments:
    1. Did you install a new 12V battery? If not, do that now.
    2. How many quarts of Toyota ATF T-IV did you fill the transaxle with? Your post says 2.5 quarts. The correct qty is ~5 quarts and the oil level should be at the bottom of the transaxle fill hole.
    3. 10W-40 viscosity oil is too thick and is not helping. The correct viscosity is 5W-30.
    4. Your OP indicated the following quantities of oil were used: 1/4 + 1 + 1.5 = 2.75 quarts which is not enough oil. However in that same post you indicated 1 + 3 quarts of oil. So which is correct?
    The engine oil capacity spec is 3.9 quarts and 3.5 to 3.75 quarts should bring the oil level up to the top dimple, depending upon how well you drained the old oil.
    5. When the car has a no-start issue so soon after it has been worked on, first consider what work may have done incorrectly. Hence my questions 2-4 above.
    6. If you don't find obvious problems, then it is time for you to purchase Mini VCI so that you can retrieve the DTC logged by your car which will give you a clue about the no-start problem.
    7. You provided a long list of items that you thought may be the root cause - rather than continue to guess, take care of #1 and #6 first. Good luck.
    #4 Patrick Wong, May 2, 2015
  5. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Thanks for all the points. Here are the answers.
    Yes, but not a new 12v prius battery, but a used one from a UPS. I don't think it's a battery, as I tried connecting it to a brand-new battery from another car (bypassing the one in the trunk) - same issues.
    About 2.5 quarts, until it started coming out of the fill hole. I didn't do a full flush, hence half of it remained in other places of transmission.
    Ok, but the prius manual says 10w-30 is ok for warm climates. Would the wrong viscosity really stop the ECU from trying to start the engine?
    Sorry, that was a "copy-n-paste" error. I think it was about 3 quarts. One thing I forgot to do is to warm the engine prior to draining the oil. In any case, the oil level is about quarter inch to the "full" mark on the dipstick.
    Yes, it's almost to the top.
    Yes, thanks.
    Ok, great. Would Mini VCI allow to trouble-shoot hybrid-specific issues or should I try to get the ScanGauge II?
    Ok, thanks
  6. Patrick Wong
    18,210
    6,513
    1. When the car is IG-OFF, what is the voltage measurement across this used UPS battery?
    2. I am wondering if your transaxle is sludged up. When you drained it, ~5 quarts of used ATF should have come out and you should be able to add ~5 quarts of new ATF. A flush is not normally needed.
    Just to make sure we are on the same page: the transaxle ATF drain plug is located on the sheet steel transaxle oil pan which is painted black. This is not to be confused with the inverter/transaxle coolant drain plug which is located on the transaxle aluminum case which is closer to the engine.
    6. Mini VCI provides the same diagnostic capability as a Toyota dealer tech enjoys and supports all Toyota vehicles. It definitely is the best diagnostic tool available and its price is minimal - so it is a no-brainer choice.
  7. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Around 12.5v. I've also tried another (almost new) battery and it had 13.6v
    Interesting. Only 2.5 quarts came out and I have driven the car just before doing the change. Any idea why only half of it drained and what to do about it?
    Yes, I used this guide (google "the pan that can change-transmission-fluid-in-2002"), but without dropping the pan.
    > brainer choice.
    Ok, great. I'll try to get it soon. Thanks again.
  8. bwilson4web
    16,366
    Just to add to Patrick's post:
    • 12.85V - great battery
    • 11.8V - worn-out battery
    • 10.xV - zombie battery
    Not starting: does it turn over at all?
    Try a double-key turn start? (1) START, (2) IGN/ACC, (3) START (easy test for obscure problem)
  9. Patrick Wong
    18,210
    6,513
    2. If you are sure that only 2.5 quarts of ATF came out and could be replenished, you may want to drain the transaxle ATF again, and then remove the transaxle drain pan to see what the underside of the transaxle looks like.
  10. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    No, the ECU doesn't event attempt to start the engine
    You mean turn the key twice in rapid succession?
    bwilson4web likes this.
  11. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Yes, I'm pretty sure, as I still have 3 bottles with the ATF fluid (two unopened and one half-full). Great, that's a good idea, I'll try it.
  12. bwilson4web
    16,366
    There is an obscure problem with the orange safety lock in the traction battery if it is partially closed or the interlock safety from the inverter cover to interlock to HV ECU is open. A double-start attempt will allow the car to start but there will be an symbol on the display.
    I see you are near:
    • Arts Automotive
    • Lucious Garage
    Both are highly respected, NHW11 expert, Prius repair shops. Certainly worth a call.
  13. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    BTW, If I want to drop the ATF pan, I absolutely need a new gasket, right?
  14. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Yes, I spoke to Lucious Garage yesterday, I need to tow the car 50mi one way and pay $75 to have it diagnosed. I'll try to find some DIY option first.
  15. Patrick Wong
    18,210
    6,513
    Yes, that would reduce the likelihood of transaxle pan gasket leaks later. You will also be able to see how much debris has accumulated on the pan, and clean the pan magnet.
  16. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Tried it this morning - didn't do anything.
    I've also noticed a strange hissing sound coming from somewhere near the engine block for the first 20 seconds when I turn the car on, it sounds like a pump running without oil/coolant. The noise is on the passenger side of the engine, so probably not an inverter coolant pump. Is oil/coolant pumps electrically driven in a 2002 prius?
  17. Patrick Wong
    18,210
    6,513
    Is the gasoline engine running while you hear this strange hissing sound? When the sound goes away, is the gasoline engine still running?
    The engine oil and coolant pumps are mechanically driven.
  18. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    The gasoline engine wouldn't start at all, the ECU would not even attempt to start it.
  19. bwilson4web
    16,366
    Power brake pump running.
    Sorry the double-start failed. Somehow I wonder if some other interlock, perhaps shifter/park, is set. Just speculation.
    I agree with getting the miniVCI as it tells all.
  20. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Ok, thanks a lot. I'll try to get the miniVCI cable for WinXP then. I hear there are 16 and 22pin versions. I found one on amazon (Fotga Newest V8.00.034 MINI VCI for TOYOTA TIS Techstream Diagnostic Cable & Software) - is it the best one out there for the price?
