Pips in traffic
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by crewdog, Apr 13, 2015.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Yea, old law. It was for safety during refuelling. I don't think it applies for EVSE.
    I have 17 miles round trip. My EV ratio is getting lower because I stopped charging. It is cheaper to run on gas now. Damn the 50 MPG engine.
    We drove to Washington DC last weekend. I got 64 MPG (no chargging) on the way back. Going there, I only have a record of 172 miles in, at a rest stop (54 MPG).
    #21 usbseawolf2000, Apr 16, 2015
  2. Tideland Prius
    16,621
    Yeah, all 2012-2015s don't use the LED DRLs.
  3. CharlesH
    2,797
    1,165
    Roseville, CA
    I wonder how long it would take for the attendant to figure out that something was amiss if a Leaf pulled into a gas station in NJ (or Oregon)?
  4. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
  5. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I have pulled into the only available spot which was on the plug side. He pushed the plug door to pop it open. It took 15 about secs for him to come to me to talk then he saw the gas side with the door partially opened and figured it out.
  6. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    Used to drive to work in downtown Sac on I50, lots of plug in green stickers...
  7. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    I don't commute so my sample isn't very large. I've only seen one other PiP in Roseville/Rocklin/Lincoln in 2 years. I see one or more non-PiP most every time I'm out and about. Of course sometimes I don't get a look at the right side of the car.
  8. markabele
    5,084
    1,782
    Nebraska
    Still have yet to see another PiP in the wild other than my own, on a dealership lot, or otherwise.
  9. PRPrius
    PRPrius Active Member
    327
    198
    I have only seen two PiPs here in the DFW metropolitan area. However, my coworker saw one not that long ago and sent me a pic. It turned out to be me! Go figure.
      File size:
      52.2 KB
    #29 PRPrius, May 6, 2015
  10. Tideland Prius
    16,621
    They were all Canadian-plated. I meant the PiP was a US-Spec car that was bought in the US and imported into Canada. We have a number of US-spec hybrids (esp. 3rd Gen Prius taxis when it was $22,000 in the US and $27,500 in Canada back in 2009-2011 and the exchange rate was 1:1)
  11. bisco
    52,390
    nebraska. you're a missionary!:p
    are you saying that you can buy a car in the u.s. and license it in canada?
    #31 bisco, May 7, 2015
  12. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
  13. bisco
    52,390
    thanks! does it work in reverse as well?
  14. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    Yes.
    However, I've been told that it's not as easy as it sounds, in either direction. You need to fulfill specific requirements, and there are lots of forms to fill out and some fees to pay. For certain cars, you may even need to get the car modified slightly, which is why there are specific models of cars that preferred for cross-border purchases.
  15. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    you live in Nebraska, come to California..
    markabele likes this.
  16. Tideland Prius
    16,621
    I think it's easier to import a car in to Canada than to import one to the U.S. just based on quick readings over the RIV and DOT.
    @bisco , most cars are compatible in both countries in terms of regulations since Canada typically follows U.S. regulations. Of course Canada has the DRL requirement so you have to ensure it has DRLs in the first place (otherwise, you'll have to get it installed before sending it off to get tested) and if it has DRLs, you can't switch it off (so disable the DRL OFF position on the headlight stalk). I think French labels are also required.
  17. Mendel Leisk
    41,901
    I see a LOT of late model cars, with BC plates and no DRL's, the last few years.
    Seems like they're getting really slack, letting US riff raff waltz right in. :whistle:
  18. Tideland Prius
    16,621
    I've seen older ones (but still new enough to require DRLs). I don't know if they're disabling it because it looks cool without it or to save money (pennies?) but when every car around them has DRLs or sometimes headlights on during the day, the car without DRLs is invisible (at least it takes me longer to find them when making a left turn).
  19. evfinder
    evfinder Member
    293
    72
    Has an interesting experience yesterday. I got to work in the morning and parked in my usual spot next to a white Chevy Volt. When I went back to the car in the afternoon the volt had gone and parked in the space was a White (BP) PIP exactly like mine. I stopped for a second wondering which was which.
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I am seeing more PiP in Fort Lee, NJ area. Mostly white ones like mine.
