resonator removal
Discussion in 'Gen 2 Prius Accessories & Modifications' started by own.the.future, Apr 11, 2006.
  1. own.the.future
    own.the.future New Member
    hey all,
    i was wondering if anyone has removed the resonator for the airbox yet?
    if so any tips?
    thanks!
  2. naterprius
    naterprius Senior Member
    1,843
    I don't think you want to do this. The atkinson cycle engine may need this for proper breathing.
    Nate
  3. talonts
    talonts VFAQman
    468
    76
    <div class='quotetop'>QUOTE(naterprius @ Apr 11 2006, 04:30 PM) [snapback]238227[/snapback]</div>
    Doubtful. Resonators are used for NVH control 99% of the time.
  4. aaf709
    3,862
    2022 Prius Prime
    Em, I'm curious. Why do you want to remove it?
  5. 240sxer
    240sxer New Member
    154
    Usually the resonators reduce the flow which often reduces the power... That's why I suppose.
  6. Screwdriver
    Screwdriver New Member
    45
    Combine your resonator removal with a K&N filter and you should feel more power instantly.
    The resonator is used SOLELY to reduce air intake charge noise. You won't create any adverse affects by doing this. Just better response and efficiency.
  7. Frank Hudon
    Frank Hudon Senior Member
    4,147
    on a 76 HP engine what is your percentage of power gain? 1%? less than 1%?
    <div class='quotetop'>QUOTE(Screwdriver @ Apr 17 2006, 03:19 PM) [snapback]241122[/snapback]</div>
    only on inline resonators. Have look at the Prius. it's added to the air box and it doesn't flow thru it.
  8. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Frank Hudon @ Apr 17 2006, 06:47 PM) [snapback]241141[/snapback]</div>
    No, it would still be the same as on other cars. If it's 10% on a Chevy, 10% on a Ford, and 10% on a BMW, then it would still be 10% on a Toyota. The perentage wouldn't necessarily vary, it's the total hp gained. So if you gain 10% on a 400 hp engine, that's 40 more hp. On our little motor, 10% is only 7 hp. But it's still 10%.
  9. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(DocVijay @ Apr 17 2006, 04:19 PM) [snapback]241161[/snapback]</div>
    it still doesn't flow thru the resonator which is the big hp killer. On the Prius it's just off the bottom of the air intake to the air cleaner.
  10. Screwdriver
    45
    Don't expect anything more than 1hp, maybe 2 with the K&N and minus the resonator.
    Most Prius owners are obsessed with efficiency, this is just another step in that direction. Obviously, the most benefit would be felt during highway passing.
  11. c4
    c4 Active Member
    607
    51
    Expect *NOTHING* in terms of HP gains on a Prius- the tiny displacement engine with its Atkinson cycle intake means that the engine is *NOT* intake restriction challenged.. It doesn't even need 300 CFM airflow at max RPM, so even completely removing the airbox (assuming that's something that you wanted to do), wouldn't help the Prius with horsepower...
  12. ScubaX
    ScubaX Member
    484
    Redding, CA
    Wouldn't this decrease the MPG? My last two vehicles where it was popular to do the K&N FIPK's, MPG was decreased 1-3 mpg.
  13. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    In the process of fooling with warm-air intakes and all, at this
    point I'm running around with the intake hose simply disconnected
    and tucked back behind the headlight. I maybe hear a little more
    intake noise from the airbox, but there seem to be no differences
    plus or minus on mileage. Finally changing the air filter, on the
    other hand, may have had a nice side-effect...
    _H*
  14. own.the.future
    reasons for removal:
    (in no particular order)
    - i like a little extra noise
    - the hunk of plastic is just a waste of space/weight
    - air doesn't have to get sucked thru a twisted tube of noise abatement - possible performance enhancement
    - i like the noise
    so i take it no one has removed the resonator from under the hood... the damn thing is really stuck in there! lol!
    anyways, thanks for all the responses...
    i ended up doing what "hobbit" did, tucked the tube behind the headlight...
  15. Escalade_on_22s
    Escalade_on_22s New Member
    70
    Las Vegas, NV
    With the Atkinson coupled with the PSD, these mods are nearly useless. Total power in KW is monitored by the HV ECU and governed. For the most part adding power to the ICE will simply charge the battery quicker, until you reach approximately 60 mph when full engine power is routed to the wheels under WOT. For uphill climbs at WOT you may be able to keep the battery charged an extra few seconds before apparent depletion (40%), but adding engine power won't improve straightline acceleration until you reflash the HV ECU with performance software. Some Japanese programmers have worked on some code, but it tends to overheat your battery due to excessive current flow. Lithium ion helps to solve this problem and unleash the potential of all 400 ftlbs available in MG1, but don't expect that until '09.
    Some guy installed a turbo on his 1st gen Prius, and the performance enhancement was noticed in terms of higher MPG and better climb performance. Here's his link: http://autospeed.drive.com.au/cms/A_2664/article.html
  16. 200Volts
    200Volts Member
    435
    45
    Northern CA
    FYI adding a K&N air filter made no change in mpg.
    Now tuning the intake length to work at say 75mph might work.
