  1. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    You'll seldom see me in this thread, as I generally prefer things stock.
    But I'm putting damping mats on the insides of the door outer skins and the difference in noise level is impressive.
    I only did the driver side Sunday and ended up driving the car to work today. Strange to have my car noticeably quieter on one side vs. the other.
    The only other mod I've done is the TRD rear sway bar that I installed a couple of months ago.
    Both mods well worth the time and effort for anyone.
  2. Boston Jim
    Boston Jim Active Member
    202
    148
    I have a new paint scheme, I call it 'pollen green', what do you think? Should I keep it or get rid of it?
    I washed and polished/waxed my wifes car on saturday so it would be pretty for Mother's day and the car was covered like this by the time I was done. But at least under all the pollen it shinny.
    I haven't yet, I was waiting until my next oil change, since I'm out of the warranty period.
  3. MeetGeorgeJetson
    MeetGeorgeJetson Junior Member
    48
    33
    Woodstock NY, USA
    Installed my Head Unit.. A Pioneer FH-X720BT, went well, despite my mechanical inabilities.. Overall fairly neat job, and only had to call Crutchfield twice.. More details on the audio section of PC. IMG_1198.JPG
  4. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    I opened a box that arrived today from another priuschat member.
  5. xcuter
    xcuter Active Member
    303
    182
    Bought the Torque app for the Prius. [​IMG]
  6. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Q: Does this monitor the status of the 12V Aux battery?
    Thinking of getting this Head Unit with OBD II.
  7. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    According to the thread regarding the PIDs for Gen3 Prius using the Torque app,
    Sergiospl likes this.
  8. scrappy
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    When I got home, I tested the LEDs using a 9v battery, all was good.
    I installed the driver side, pulled the wires into the cabin and tested again with a 9v battery to make sure the wiring was still bueno. Getting the mirror to snap back onto that white plate on the motor was kind of a a bitch, but everything was otherwise fairly straightforward given that I was following the steps others here have documented so well
    Now I need to read through the 50+ page install thread to understand how to properly wire the lights up to the car.
    Testing pics...
    puddle light
    pilot light
    signal light
  9. dle
    dle Junior Member
    65
    SoCal
    Wire the driver side to driver side footwell, do the same for the passenger side on the passenger footwell. Run the puddle/courtesy lights to the harness for the overhead dome (above the shifter). That's what I did for mine.
    scrappy likes this.
  10. Xterra72
    Xterra72 Senior Member
    1,436
    1,681
    Not liking too much orange, so I gave it some shade.:cool:
  11. ncases
    ncases Senior Member
    609
    672
    Chicago
    I installed cheap fog light kit from ebay and the switch stays on even when ignition is off.
    I realized that the 12V that feeds the switch LED came from the fuse box where it supplies the fog lights and thats the reason why the lights remains on. So I revised by rewiring it.
    There are 3 wires the goes to the fire wall/ the black with white sripe wire is the 12v that goes to the switch and the brown wire is the 12v back to the relay. I snip the black wire (ground) which I don't need since I tap this wire to the bolt under the dash
    Here's the revise switch.
    Sleeves on for neat install.
  12. aportades
    aportades Team Thrust Racing
    76
    177
    San Diego, Ca.
    Gave my Prius a carwash today. Also keeping my mods simple and clean
  13. Gaspeed
    Gaspeed Senior Member
    286
    1,624
    San Diego CA
    I also gave the Prius a wash today. Simple nice and clean
  14. C.R.E.A.M.
    C.R.E.A.M. Member
    55
    68
    39
    Sacramento, CA
    Thanks for the info... I'll be doing this soon.
  15. ncases
    609
    672
    Chicago
    Let me know i can assist you with the wiring.
    C.R.E.A.M. likes this.
  16. scrappy
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    I just finished wiring the LED mirrors and I think everything works as it should. I followed Sean's wiring guidelines for the most part, except that I tapped the footwell light for always on 12v power to the puddle lights.
    Thanks to Sean and others who posted the excellent install instructions and pics on this forum.
    sfv41901, Accordlayingkit and ncases like this.
  17. ncases
    609
    672
    Chicago
    You can tap your puddle light through the blue wire on the A-pillar. It's intimidating but it's worth the try. I tapped my footwell light back and front, door sill plate to the A-pillar blue wire.
    iPhone ?
    #7277 ncases, May 13, 2015
    Accordlayingkit likes this.
  18. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Bought me some tires for new wheels. (y)
    sfv41901, Burna J and Accordlayingkit like this.
  19. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    How big did you go
    How big did you go? What is the weight of rim + tires? The CT200h was around 45 lbs
  20. scrappy
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    Yeah, I tapped that blue wire right at the headliner, to tie into the puddles' black wire and the footwell light feeds the puddle's white wire. After skimming much of the 53 page LED mirror thread, it seems that discovering that blue wire was a huge find that simplified the puddle lights wiring for knuckleheads like me to get a clean and correctly functioning install.
    ncases likes this.
