I think I just saw the Gen 4 Prius (in stealth)
Discussion in 'Gen 4 Prius Main Forum' started by savior1974, May 14, 2015.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Good eye!
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Too bad it didn't start raining and all the tape came off. :D
    WE0H likes this.
  3. inferno
    inferno Senior Member
    1,072
    405
    Maybe it's it !! Or maybe it's the plugin version. The front looks more ford fusion to me could the Gen 4 be a cross between a fusion and volt ? Am excited though ...more to come for sure, I bet u before the volt 2 release.
    Why would the tape a gen4 no . Tests should be done. So maybe it is the pip after all which might be 6 months after
  4. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Seems longer from the C pillar/rear door to tail light!
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Interesting find.
    But unless the Gen 4 Prius is based on a new "Duct Tape" platform, I can't really tell too much.
    Radiohound and WE0H like this.
  6. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Do remember they can put "stuff" under the tape to conceal the -actual- shape.
    It's just the "spy vs spy" thing car manufacturers do. It's a very competitive market.
  7. KomaiaBoyz
    KomaiaBoyz Junior Member
    Still have to put gas in it
  8. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    I have that happen to me on occasion!!!
    WE0H likes this.
  9. Sergiospl
    3,938
    1,351
    28
    What! a little pregnant? :D
    WE0H and That_Prius_Car like this.
  10. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Interesting. It looks like the windshield won't be as steeply sloaped and at the same angle as the hood.
    I can't tell too much yet, but I can say that I don't like the way the narrower windshield is.
  11. Veloist
    Veloist Junior Member
    SF Bay Area
    Great find...
    You can see the Prius in front has one of those Michigan Manufacturer's plate. They usually drive in packs!
  12. JC91006
    JC91006 Senior Member
    16,781
    8,576
    This one ran low on fuel and the pack left him
  13. scripto
    scripto Junior Member
    55
    Austin, TX
    The tail looks different than any spy shots we've seen. It does remind me of the squared off, sedan-ish volt. I wonder if they had trouble with rear visibility with the redesign, and they eventually decided to ditch the vertical back window and drop the upper hatch window at a steeper angle. Surprised they'd still be changing such things so late in development, but it would explain the delay and lack of info.
  14. Veloist
    SF Bay Area
    Haha but there is actually a Grey Gen3 Prius getting gas too in the booth in front of the test mule! That's the one with the Michigan plate.
  15. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
  16. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The hatch looks shorter and hood longer.
    The tire look to be lower profile. Either 60 or 55 instead of current 65.
  17. The Electric Me
    9,083
    5,801
    Do you find it kind of funny that Toyota and most other manufacturers are reduced to concealing their vehicles or masking the reality, using duct tape and popcorn peanuts?
    I mean it's OK, and I understand why they do it, but given that they are one of the largest builders of auto's in the world, you'd think they could be a little more sophisticated in their efforts to obfuscate than "Let's wrap her up in duct tape and electrical tape and take a road trip".
    I sometimes wonder how much of happenings like this aren't orchestrated with an eye to building up excitement and hype about an upcoming vehicle, MORE than any real desire to keep the vehicle prototype hidden from the competition.
    Happenings like this are inevitable and the publicity they generate is golden.
  18. Sergiospl
    3,938
    1,351
    28
    Does the hatch seems curved a bit?
  19. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    May be if I am bored I will tape some boxes board on mine and drive around DT SF :p
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Ya, looks more like sedan than straight match.
