  1. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    ...upgraded MPG :p
    xliderider and Accordlayingkit like this.
  2. SubCode
    SubCode Senior Member
    739
    1,341
    im getting 50MPG..with factory 17's[​IMG]
    Accordlayingkit likes this.
  3. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Installed my new striker covers.
    Before:
    After:
    They are a perfect fit and just snap right in.
    nedear88, TopRamen, ncases and 7 others like this.
  4. Dylan Doxey
    1,389
    3,459
    92
    I also de-yolked my turn signals today.
    Before:
    Although I have LEDs installed, the Yellow plastic base of the LED creates the blaring yellow reflection.
    I ordered some foil tape on Amazon and did it up ...
    After:
    This makes my day.
  5. Todd36
    Todd36 Junior Member
    APG Maryland
    Disabled tpms sensor (thanks peef) no more annoying orange light!
    Also rear wiper delete.
    C.R.E.A.M., ncases, Johnsk93 and 8 others like this.
  6. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
  7. Dylan Doxey
    1,389
    3,459
    92
    The LED bulbs also require a new flasher module. So, you'll need to do all four (front & back) at the same time.
    Here's where I got my goods:
    (Amazon product codes B00K5WF6L6, and B00KQUX4F2.)
    I can't say these are the best. They're certainly not the cheapest. Had I known him at the time, I would have asked @sfv41901 who is a retrofit lighting guru where he would buy them.
    And .... technically, you might be able to mix incandescent and LED bulbs while using the original flasher module. That would require installing load resistors. I fiddled around with that and got frustrated. So I went all-in with four LED bulbs and the new flasher module.
  8. xliderider
    xliderider Senior Member
    8,083
    3,236
    Honolulu, HI
    You can mix incandescent and LEDs with the new flasher module, so you don't have to go "all in". ;)
    Dylan Doxey likes this.
  9. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
    Still looks good!
  10. TopRamen
    307
    578
    Fremont, Ca.
  11. ncases
    ncases Senior Member
    609
    672
    Chicago
    I did place some double sided tape it will fall off overtime.
  12. Dylan Doxey
    1,389
    3,459
    92
    For some reason the site filtered out the Amazon links above. You can find them by searching Amazon product codes B00K5WF6L6, and B00KQUX4F2.
  13. Dylan Doxey
    1,389
    3,459
    92
    Thanks, I'll keep an eye on it. Those LEDs can get pretty hot if they're on for long. They got almost too hot to handle because I was running the flashers while I was doing this.
    This is the tape I used:
    That's Amazon product code B007Y7E95Y. It's not double sided tape. It's just tape with aluminum foil on one side.
    EDIT: Oh, never mind. I thought you were talking about the tape I put on my turn-signal bases.
    Are you saying that these striker plate covers will fall off?
    #7333 Dylan Doxey, May 17, 2015
    ncases likes this.
  14. TopRamen
    307
    578
    Fremont, Ca.
    Actually, do you have the link to the striker covers. Cheers!
  15. Dylan Doxey
    1,389
    3,459
    92
  16. TopRamen
    307
    578
    Fremont, Ca.
  17. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Bet you wish you wouldn't have said this bro! o_O
  18. Xterra72
    Xterra72 Senior Member
    1,430
    1,676
    The curb rash i gave myself last week was actually from trying to squeeze into a right turn with a curb next to it. It was too tight and I grazed the curb.
    So it was not from a curb tuck parking. I am still in the process of causing that damage.:D
    I'm just glad I did not hit the prius plus kit on the curb.
    #7338 Xterra72, May 17, 2015
    sfv41901 likes this.
  19. Sweet n Low
    Sweet n Low Junior Member
    24
    Hey what's up fellow P.C. members so today got to finish tinting my front turn signals but some how I managed to break the plastic piece near the ball on the hood latch cable .has anyone here had to change there cable? I searched around all I really seen was for the 2nd Gen prii ..I did a lil tracing of the cable n found if u jack up the drivers side n pull the wheel well plastics down the cable goes in the cabin from there anyone have any tips or tricks before I tackle this....
    Pics of the turn signals
    Pics of the broken plastic
    #7339 Sweet n Low, May 17, 2015
    ncases likes this.
  20. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    Which lowering kit are you using?
