Before I spend a lot of money
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shells2skis, May 15, 2015.
  1. shells2skis
    shells2skis Junior Member
    51
    AZ
    I have ordered the mini vci but haven't gotten yet. I just want to make sure I need a new battery. Symptons were battery at first start in morning blue then quickly discharged to black (empty) the quickly recharge to green. Now this is what my dash looks like
  2. Patrick Wong
    18,200
    6,500
    1. Which battery are you referring to? If the traction battery, you need to see what the DTC are before you commit to a replacement.
    2. I suggest you buy more fuel, soon.
  3. bisco
    51,844
    generally yes, that means your battery is bad. how many miles on her?
  4. shells2skis
    51
    AZ
    The traction battery. I didn't want to fill it if it was just going to sit in the driveway.
  5. shells2skis
    51
    AZ
    107,399 miles
  6. bisco
    51,844
    ouch, just over the limit. still, you're might get some financial assistance from toyota.
  7. shells2skis
    51
    AZ
    Toyota customer service said no. I am trying the dealer now.
  8. shells2skis
    51
    AZ
    This car has needed every recall. Dash went in August. Now, the battery.
  9. bisco
    51,844
    unfortunately, the arizona weather seems to be tough on batteries.
  10. ChapmanF
    18,078
    Looking at only your dash lights and symptoms, what we know is that you have a problem of some kind, and it even probably has to do with the battery. Waiting for the Mini VCI will make it easier to decide whether there's a problem that can be inexpensively repaired in the battery you have, or one that essentially requires a rebuild or replacement.
    -Chap
  11. shells2skis
    51
    AZ
    Just my luck, nothing likes the weather here.
  12. shells2skis
    51
    AZ
    Ok, I will try to wait until I receive it. Just want to make sure it's the battery in case I run out of patience.
  13. dougz4m
    dougz4m Junior Member
    San Juan, Puerto Rico
    mine just lost power while driving and I can't get the dash on. It's a 2005 Prius with 89000mi, yesterday while driving my dash lights came on and I got to see a Problem message before coasting to the curb. I took the 12V battery to the Toyota dealer and it was good, dropped it in and tried to start the car but all it does is show these rectangles(can I upload a video?) for a second and nothing happens. The rectangles are the ones around D ,P ,N ,B. Any idea?
  14. JC91006
    JC91006 Senior Member
    16,762
    8,562
    You need to have the codes read, there's probably a serious issue with your car
  15. dougz4m
    will do asap!
  16. Patrick Wong
    18,200
    6,500
    Based upon your message, I assume that the dashboard is dark after the gear selector rectangles go away?
    1. My first idea is that you need to buy a digital multimeter so that you can measure voltage across the 12V battery and resistance across a couple of fuses.
    2. My second idea is that you need to measure the voltage reading across the 12V battery. A fully-charged AGM battery will measure ~13.0V while a discharged battery will measure ~12.0V. (You can see that I would not trust your dealer's tech to be able to evaluate the battery condition.)
    3. If the battery is good, then my third idea is that you need to inspect the following: AM1 and AM2 fuses, and IG1 and IG2 relays. Use an ohmmeter to verify the fuses are good, do not rely upon visual inspection. To check the relays, remove each relay, apply 12VDC to the relay coil terminals and measure resistance across the switched terminals. Replace if resistance exceeds 0.5 ohm after accounting for resistance of the meter leads.
    4. If you don't find a problem with #2 or #3 above, then buy Mini VCI so that you can have the DTC read to get a clue about what is wrong with your car.
  17. shells2skis
    51
    AZ
    I have what might be a stupid question to some. Why doesn't a battery light come on or is that supposed to be the red car with the ! going through it?
  18. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It is a catch 22 situation, a computer to test for a bad battery would be powered by the same battery it was trying to test.
  19. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    1,007
    I have a 2006 that had the dash go out 9 years and one day from the date placed in service. Toyota said no.:mad:
  20. strawbrad
    953
    1,007
    The stupid thing is these cars do not come with a 5 digit display from a $2 calculator that would just display the codes.(n)
    Before you get your Mini VCI read this short thread. Unable to determine the cause of the triangle warning | PriusChat
    It will show you how to use Techstream to monitor a charge and discharge test. In less than 10 minutes while sitting in the drivers seat you will know the condition of your battery before taking anything apart.
    Brad
