How to remove the cover behind the wheel
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by hj630, May 15, 2015.
  1. hj630
    hj630 Junior Member
    26
    Naperivlle
    I bought a auto light kit but no instruction on how to open the cover behind the wheel so I can access to the the wires. Also how can I remove the cover on the lower left corner to access the ACC?
    Thanks in advance~
  2. ChapmanF
    18,558
    manuals at techinfo.toyota.com
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    To remove the two covers surrounding the steering wheel there's a hole on both sides of the steering wheel, in the cover, that you push in with a small screwdriver.
    It's in this thread:
    JDM Prius Steering Wheel | PriusChat
  4. hj630
    hj630 Junior Member
    26
    Naperivlle
    Thanks. I used the picture from the thread you gave me. I actually want to remove the cover here to access to the stalk for adding auto light. xlider, are you talking about those two holes in the picture. I tried to stick a screw driver in but still cant get the top and bottom cover out...[​IMG]
  5. xliderider
    8,140
    3,277
    Honolulu, HI
    I've never done it myself, but I believe the holes are on the sides, not the front, like in your picture.
