Newbie in trouble: "Check hybrid system"
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RogerHq, May 22, 2015.
  1. RogerHq
    RogerHq Junior Member
    70
    SWEDEN
    Hello folks!
    Bought a used Prius 2010 last december, used as a taxi cab i Sweden.
    Now the hybrid system is shut down and the assumption is that the hybrid battery is the culprit.
    No codes has been read out of the system but the car has passed 330 000 km so I guess that's very plausible.
    Have found a used battery from a 2009 prius who the local Toyota service facility says is compatible.
    I guess I could do the replacement myself saving some $400?
    Any thoughts about that?
    Cheers! /Roger
  2. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    In a USA model I don't think that would work.
    The US 2009 is a Gen2 and a 2010 is Gen3 with a slightly different battery design.
    The individual modules (28 in Gen2 vs. 32 I think in a Gen3) may be tranferred Gen3 to Gen2 but vice versa is not as easy cuase you are missing some modules. But I don't know if EU has same batteries or model years. GrumpyCabbie can tell you.
    PS- Welcome!
    #2 wjtracy, May 22, 2015
  3. JC91006
    JC91006 Senior Member
    16,803
    8,592
    Does the car start and still move? If not, it's probably not the battery.
    There should be codes in the car if the hybrid system has failed. Just bring it somewhere (like the dealer) to get it diagnosed.
    On a gen3, I would suspect the inverter to be the problem
  4. RogerHq
    70
    SWEDEN
    Yes, the car is running without hybrid functionality.
    I'm not sure my mec guy has the right kind of equipment to interperet the codes properly and the dealers i taked to just want me to make an appointment somewhere in the distant future, i don't want to wait for that.
    I remember I saw a note somewhere about a PC-based HW suitable for Prius on this site?
    Can I disable the error state somehow, the car has recharged the hybridbattery after the fail state appeared, that's why I believe it is the battery.
    /Roger
  5. JC91006
    16,803
    8,592
    can you elaborate on how the car runs? The car needs hybrid functions to actually work
    valde3 likes this.
  6. RogerHq
    70
    SWEDEN
    Well, U start the car as usual with he difference that the combustion engine always runs.
    Most of the other funcitonality are there, the hybrid battery is charged as needed for support of 12V charging and the AC but not for the electric motor. The ordinary display pages showing hybrid performance is obscured by the "CHECK HYBRID SYSTEM" message but those pages can be momentarily displayed by, as usual pushing the "DISP" button.
    #6 RogerHq, May 23, 2015
  7. RRxing
    RRxing Senior Member
    2,553
    1,826
    NEPA
    Without codes, we're just shooting into the dark...
  8. bisco
    52,239
    generally a sign of hybrid battery failure, but not definitive.
  9. JC91006
    16,803
    8,592
    You need the codes read, it might not be a battery issue
  10. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I thought this could be inverter coolant overheat.
  11. Patrick Wong
    18,210
    6,511
    How do you know whether "hybrid functionality" is present or not?
    You need Mini VCI if you want to DIY retrieve the diagnostic trouble codes. This runs on a Windows 7 or Windows XP, 32 bit OS laptop.
    I agree that it is very premature to replace the traction battery without knowing the DTC. Your car could have other problems, for example the inverter or transaxle.
  12. Mendel Leisk
    41,791
    I would persevere in getting a dealership appointment.
  13. RRxing
    2,553
    1,826
    NEPA
    Some auto parts stores will read the codes for you...
  14. RogerHq
    70
    SWEDEN
    Codes read:
    P0571
    P0A0D
    P0A80
    That means I need to do at least two things, first correct answer will be served a beer at a suitable Point In Time...
  15. RogerHq
    70
    SWEDEN
    BTW, my hybrid system runs again, without any action except what?
  16. RRxing
    2,553
    1,826
    NEPA
    The brake switch is an easy fix. As for the hybrid battery codes - good luck.
  17. RogerHq
    70
    SWEDEN
  18. Patrick Wong
    18,210
    6,511
    P0571: replace brake light switch
    P0A0D: correctly install the orange traction battery interlock switch
    P0A80: replace the traction battery, or at minimum the failed module(s) within
    Correctly setting the interlock switch. However that will not last as the traction battery continues to deteriorate. I would not install used G2 modules into a G3 traction battery case.
  19. RogerHq
    70
    SWEDEN
    I also thought it was a brake issue but when U read the code list I'm not so sure anymore.
    The code P0571 is under the cruise control header and I do in fact have problem with that function but also with my brake pads...
    Ok, now I discovered your links!
    I guess there is an error in the list I gave a link to...
    /Roger
    #19 RogerHq, May 30, 2015
  20. RogerHq
    70
    SWEDEN
    Well, I did remove the service plug when the system was down but the 12V battery was -not- disconnected.
    I geuss that's why that code apperared?
    I believe the battery pack is the same as in my G3 car, according to a Toyota dealer. I think he said that late Gen II-cars have the GEN III-batterypack?
    Anyway the type code is the same.
    This is a European car, maybe it's different in the US?
    #20 RogerHq, May 30, 2015
