ABS C1256 and C1378 error codes
Discussion in 'Gen 2 Prius Technical Discussion' started by goitalone, May 23, 2015.
  1. goitalone
    goitalone Member
    190
    Port St. John, Florida
    Anyone know what these error codes indicate?
    I cannot find much info on them.
  2. ChapmanF
    18,447
    Have you found techinfo.toyota.com?
    Some people don't right away, I guess because it's a different URL from the main Toyota site.
    -Chap
  3. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    C1256 ACCUMULATOR LOW PRESSURE
    You should get the sub code for this. Is it 141 or 143?
    C1378 CAPACITOR COMMUNICATION CIRCUIT MALFUNCTION
    You should get the sub code for this. Is it 112 or 113?
    Both of those sound pretty weird problems. Did you have something unplugged? Has there been accident damage to wiring? Have you tried to clear the codes? Do they come back? When?
    Have you tested the 12V battery? It can sometimes generate random fault codes if it’s bad.
  4. goitalone
    goitalone Member
    190
  5. goitalone
    goitalone Member
    190
    Only thing I can think of is serveral months back I ordered a brake accumulator used from eBay and had a mechanic install it. May be something to do with that. No accident, but I did just replace a cell module in the HV pack.
    Just replaced 12v battery three months ago.
    Where do I find sub codes?
    The codes showed up as current, but I will clear them and see what happens.
  6. Singh.seattle
    Singh.seattle Junior Member
    Seattle
    I got c1256 on Prius 2008 with detailed dtc 141? what is the cause sir?
    yes the car was in minor front left (driver side) accident too.
  7. Marty2go
    Marty2go Junior Member
    40
    Ohio
    Four Touring
    I think C1378 it's because you have the power control module unpluged in the back by the 12 volt battery
