Prius v (lowercase v) Storage
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Trucking Girl, May 24, 2015.
  1. Trucking Girl
    Trucking Girl New Member
    My 2014 Prius v (lowercase v for the Prius v wagon) is in storage in a relative's garage in Florida for 5 months. Can I leave it there and not have them start the car for the 5 months and not have any problems?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    It would be ideal for it to be started monthly. The 12v battery wants it.
  3. Trucking Girl
    If they start the car and pull it out into the driveway, would that discharge the hybrid battery if it is just sitting in the driveway and the car is in "P" and appears to be not running?
  4. mikefocke
    3,991
    1,801
    Sanford, NC
    Remove 12v battery, place it on battery maintainer, reinstall when you are ready to use the car again.
    Other classic things to do before storage:
    1. Pump up tires several pounds, park on pieces of plywood. Tires won't flat spot as much.
    2. Change oil right before storage. Store car after run to get engine thoroughly hot. That way less water vapor in the oil in the crankcase on the bearings, cylinder walls, rings, etc. Run gently for first 10 miles after startup.
    3. Place rodent repelling material near and in car.
  5. Mendel Leisk
    41,363
    ^ The battery maintainer should be "smart", ie: designed to be left on indefinitely. Also, in the 3~4 amp range, no more.
    ^ Set tires to max sidewall pressure, or alternatively/preferably: put the whole car on jack stands, even with the tires still touching, but raised enough that most of the car's weight is off them.
    Leave one window slightly down.
    Put rags under the wiper arms, to raise the wipers slightly off the glass.
    Leave the car with a full tank of gas. You might want to put some gas stabilizer in too, wouldn't hurt, though 6 months is not that much. Prius plug-in owners might go that long on a tank.
  6. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The system starts the gas engine and charges it.
  7. Air_Boss
    Air_Boss Senior Member
    4,194
    1,180
    New Yawk
    Echo the smart charger - like a CTEK 3.2 Amp unit.
  8. rjparker
    10,111
    6,272
    Personally I would ask them to drive it every three weeks or so to really keep it ready. But short of that I would at least hook up the 12v battery charger using a quality unit such as Deltran's Battery Tender Junior, available widely online and at retail stores:
    021 0123 Deltran Battery Tender Junior 12 Volt 75 Amp Jr Maintainer Charger 12V | eBay
    Note: You can't trickle charge through the cigarette lighter/power port inside a Prius. It's disconnected with the car off. So the best place is at the 12v battery itself under the rear hatch covers or hooked up to the "jump" connection in the fuse box under the hood. Both are a little difficult for someone who has never done it before. Also be VERY careful if you end up jumping the car from another source later on as a wrong polarity connection will cause some parts of the car to fail.
    #8 rjparker, May 24, 2015
  9. mikefocke
    3,991
    1,801
    Sanford, NC
    A maintainer is different from a charger. The maintainer asks that the battery be initially charged and then turns itself on every once in a while and checks the battery state of charge and, if needed, charges but very slowly until it reaches the battery fully charged point at which it goes to sleep only to wake up occasionally and check. We use these all the time in over-winter storage for expensive sports cars. Because they won't overcharge/cook the battery like a charger can.
    I've used a ctec model, but the Battery Tender Junior is also fine and cheaper.
