  1. Collinator
    Collinator Junior Member
    Houston, TX
    This is what I was searching for. Thank you, friend!
    Dylan Doxey likes this.
  2. SubCode
    SubCode Senior Member
    739
    1,341
    no noticeable difference..ride exactly as it did before.
  3. SubCode
    739
    1,341
    yeah...I had to spend a lot of time and I did ask other posters for answers..but as usual the best teacher is your own experience...so when I do something that is important I document and wait for the feedback...and like talking to a friend..the forums will say you got it right, or you got it wrong...so yeah having this forum is great. Having a category for install tips (DIY) would be easier to get solutions and not waste time..trolling other websites of vendors and other forums for answers , because we're all trying to save time and money.
    sfv41901 likes this.
  4. Hugo Sanchez
    Hugo Sanchez Member
    30
    63
    LA 323
    Finally got around to putting on my roof rack and installed some JDM window visors #murkedcity
  5. John75
    John75 Junior Member
    25
    52
    Outside Philadelphia
    What headlight bulb is that? Aftermarket HID or LED in the halogen projector?
  6. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Yellow LED. No need for ballast. It will fit in low beam. But you have to take out the bumper to install. I recommend for fog light. I test drive the car this morning. The thing is very bright. I pointed below my low beam.
  7. John75
    25
    52
    I meant in the regular headlight - it's got some highlights above the cutoff that will probably get a lot of people flashing lights at you...
  8. apt5020
    881
    1,294
    Prius City, CA
    Probably not. The HID are brighter then the LED. Really depend where you pointing your headlight.
    Sweet n Low likes this.
  9. xliderider
    xliderider Senior Member
    8,056
    3,224
    Honolulu, HI
    All of the Prius lowbeam projectors have that. Google search "squirrel finder cutouts", they are small openings in the cutoff shields that allow light above the cutoffs. Typically, they allow one to see overhead signs and roadside signs that are further down the road, that are beyond the cutoff points for the lowbeam headlights.
    Since HIDs are several times brighter than halogens, it can be a significant source of glare. Some people bend the metal tab that creates the squirrel finder cutouts closed and seal them with JB Weld to mitigate this glare. Most do not.
    Here's a thread discussing them, and a picture:
    How to Fix Squirrel Finders
    #7449 xliderider, May 26, 2015
  10. John75
    25
    52
    Funny, I didn't know that the term was used on other kinds of cars - I had the same issue with a Subaru where I did drop-in HID kits (into OEM projectors) and had to fix them. I constantly had people flashing lights at me until I resolved it:
    [​IMG]Subaru Legacy Headlight Pattern by John Abella, on Flickr
  11. Xterra72
    Xterra72 Senior Member
    1,429
    1,673
    Another small mod came in yesterday. Toyota oem front chrome garnish....:)
    That completes my chrome accents.(y)
  12. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Looks really well man! (y)
    Xterra72 likes this.
  13. apt5020
    881
    1,294
    Prius City, CA
    My chrome garnish was bent during shipment. Not even sure they going to sent me another one. Bad packaging...I haven't gotten a respond from them yet.
  14. Xterra72
    1,429
    1,673
    Sorry to hear that. My box was slightly bent but I was lucky the item was okay and undamaged.
  15. C.R.E.A.M.
    C.R.E.A.M. Member
    55
    68
    39
    Sacramento, CA
    Newly painted gloss black roof :cool:
    New fog lights
    New hard wired dash cam
    I have bumperplugs but still need a tow hook license plate mod.
    Next plan is to change the antenna to a shark fin. (black)
    #7455 C.R.E.A.M., May 27, 2015
    TopRamen, Starbrand, Johnsk93 and 5 others like this.
  16. apt5020
    881
    1,294
    Prius City, CA
    Where did they tap the dash cam? I was thinking of the cigarette lighter
  17. C.R.E.A.M.
    C.R.E.A.M. Member
    55
    68
    39
    Sacramento, CA
    Dash Cam is that tiny screen near the top left.
    I ran the cable under the headliner, down the pillar, into the dash, behind the head unit. I tapped into a wire that was not being used on the stereo, so the camera turns on and records when I start the car, then shuts off when the car is powered off.
    Oh, and I also have some new blue interior lights
    #7457 C.R.E.A.M., May 27, 2015
    TopRamen likes this.
  18. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    For switched power to my dashcam, I tapped a wire on the ECU plug that is hiding behind the mirror switch dash panel. It's been a while but IIRC it was a blue wire.
    C.R.E.A.M. likes this.
  19. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Installed the Htech and TRD rear swaybar.
    Springs are lower and stiffer than nf210's.
    Lowered tire pressure to 37 psi front & 35 psi rear.
    No complaints from my Pregnant Wife(y)
    Now I'm selling my Tanabe nf210
    Here's the link For Sale - Tanabe NF210 lowering Springs | PriusChat
    #7459 granTORRESmo, May 27, 2015
  20. SubCode
    739
    1,341
    What LED bulbs can you get for the headlight the row of lights above the projector?..
