Increasing dash backlight
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Rhinoruns, May 29, 2015.
  1. Rhinoruns
    Rhinoruns Member
    61
    Madison, WI
    Hi. When I turn on the headlights of my 2010 the dash backlight dims considerably. It becomes difficult to see/read when the sun hits it just right...especially wearing polarized sunglasses. I have the dimmer switch set all the way high. Is there a way to increase the backlighting or have it not dim as much with the headlights on?
    Thanks
    52,417
    i don't use my headlights in the day, just for that reason. i wonder if led's would help?
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Do you have the dimmer set to Max? Not just rotated up, but turn it harder till it clicks up, past a detent, all the way to Max setting. It gets Much brighter on Max setting, I can see it fine with my polarized sunglasses.
    The navigation screen is a whole other story though. :rolleyes:
    Dylan Doxey, bisco and Rhinoruns like this.
  4. Rhinoruns
    Rhinoruns Member
    61
    Madison, WI
    OMG GENIUS! Yep! That was the trick!!! Didn't realize it 'clicked' up beyond max. :) :) :) :) :) :)
    Accordlayingkit and Dylan Doxey like this.
  5. xliderider
    8,140
    3,277
    Honolulu, HI
    Glad to hear it. :D
    MeetGeorgeJetson and Rhinoruns like this.
  6. bisco
    52,417
    good call, i thought he already had it up all the way.
    Rhinoruns likes this.
  7. xliderider
    8,140
    3,277
    Honolulu, HI
    Yep, there's a big difference between pseudo max, and the max setting beyond the detent. If he can't see the dash on Max, then he shouldn't be driving. ;) :D
  8. pauerbach
    pauerbach Member
    101
    34
    I've noticed a lot of Prius drivers using their headlights during the day. I'm curious why, considering the car already has daytime running lights.
  9. xliderider
    8,140
    3,277
    Honolulu, HI
    The 2010 -2011 Prii didn't have DRLs. And the dealers apparently aren't good about showing new users how to turn on the drls.
