prius c loose front fender
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by emily's prius c, May 30, 2015.
  1. emily's prius c
    emily's prius c New Member
    MA
    I clipped a snow bank this winter and now my front bumper is popped out at the seam on one side. I don't know if it is missing a piece to clip it in place? How would i fix this?
  2. Super Mario
    Super Mario Member
    142
    57
    Medford, NY
    That looks like the front bumper. If it's the bumper it clips in and if it won't clip in then the clips probably broke and you need to replace them or bring it to get fixed. If that's the fender then yo need to bring it to Toyota or a body shop to fix. Try pushing in on it around the seems where it meets along the bumper and see if it snaps back in
  3. Okinawa
    Okinawa Senior Member
    1,333
    320
    I would take it to a body shop.
  4. izzmo
    izzmo New Member
    Portland
    2016 Prius c
    I'll resuscitate this thread, since i have a similar issue. I've been struggling to identify the part number for this clip, which is clearly missing. I found this diagram for the front bumper on lakelandtoyota, but it's not very clear what's what.
    Would appreciate the help tracking down the part! Thanks!
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  5. BiomedO1
    3,556
    1,845
    SacTown, Ca
    I believe the part your looking for is #6, in your diagram. Do a very close inspection of the edges of part #1. If the lock points are not intact, ripped out; replacing part #6 won't do you any good.
    I removed part #1 on my old 2012 Prius C, to push out a dent - those lock-tabs are pretty brittle. Try just pushing it back in, to see if it'll locks back into place.
    Good Luck...
