Constant gas pump shutoff when refueling
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by UoD, Aug 26, 2011.
  1. qdllc
    qdllc Senior Member
    1,377
    400
    Are you getting gas at the same place? Does it happen every time you gas up?
    I ask because I've not seen this happen, BUT there was the occasion where the "auto shutoff" was very twitchy at the station I happened to be at...forcing me to pump the gas manually and slowly.
    I think some places make the pumps run too fast, and it creates the very conditions that triggers the pump to shut off THINKING the tank is almost full.
  2. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    If you find yourself in this situation, turn the pump upside down, trigger on top, works every time.
  3. Mendel Leisk
    41,804
    Same here: once in a long while I'll get a touchy pump, say a single pump at one station, where it's shut-off prone. Just baby it and it's ok. Not sure what happens, maybe the mechanism clogs or something? But pretty rare occurrence.
  4. Martyelzz3
    Martyelzz3 Junior Member
    Sprague, WA
    I've had it happen twice recently, on my 2012 Prius II, once at COSTCO and once at a Chevron. At the Chevron I backed the nozzle out as far as I could and put it on the slowest flow notch.
