How important is it to buy and install a "Grid Charger"
Discussion in 'Prius v Accessories and Modifications' started by Eric "v", May 28, 2015.
  1. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    I see grid chargers advertised as the way to "balance" my traction battery pack and get more power from it on a regular basis.
    The ad appears to talk a lot about Honda hybrids and little about Prii.
    Is there anyone here who owns a grid charger?
    If so does it work as advertised?
  2. Mendel Leisk
    41,824
    I followed the story of a guy on CleanMPG: installed and used a grid charger on a second gen civic. He was experiencing very frequent recalibrations: Honda-Speak for a dying battery and the car's computer attempts to reassess it's state of charge. Anyway:
    He hung in there for a while, charging sessions, research and discussion. He had a good attitude, stuck with it, but within 6 months or so gave up, sold the vehicle.
    The IMA battery is a real debacle though, not sure regarding Prius.
    #2 Mendel Leisk, May 28, 2015
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    It seems that batteries in hybrids don't fully charge in the first place for longevity. I think one would be chasing pennies with dollars so to speak.
    MT2L03 ?
  4. bisco
    52,286
    there is no proof that grid chargers work on healthy batteries. it's only people who are having problems that use them. and then, we have nothing showing rate of success.
    it's like the post: i through a bottle of techron in when i fill up, and my car runs better.
  5. Air_Boss
    Air_Boss Senior Member
    4,218
    1,188
    New Yawk
    Buying and applying the product endorsement stickers may be all that's required.
  6. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    Running and driving your car will charge the battery the same as a grid charger if not better (when using regenerative breaking). Grid chargers are good if a battery was depleted because it has been sitting unused for extended periods. Other than that there's no need to have one unless you are in the hybrid battery repair business.
    Fermy likes this.
  7. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I let the v sit for many months. No problems. Just kept a AGM battery charger on the jump points under the hood.
    MT2L03 ?
  8. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    jz,
    Where are the "under hood jump points"? I thought I'd read my owner's manual pretty well but failed to notice that, which is a pretty important point.
    I came home after over a week away and found my battery in the "purple zone" so I took it on a 40 mile highway drive to recharge it.
  9. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    It's in your owner's manual. At the back of the engine bay fuse box, covered with a red plastic cover is the positive terminal jump point. Negative is any good bolt or bracket nearby.
  10. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Positive is like xliderider says. Pop the lid of the fuse box. There is a little red cover you flip open to access. The neg is a metal piece sticking out just to the bottom left, facing the car, of the engine cover.
    It is definitely in the manual. Sorry, I'm tired, it's dark outside, and I'm not very good at attaching photos....
    MT2L03 ?
    depriusoto likes this.
  11. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    Thanks for the jump charging info.
    I can see from the grid charger ad that it is really much better for the Honda hybrids whose hybrid batteries have "issues". I won't be investing in one of those since Toyota's system is self-sustaining.
    kiwi and bisco like this.
  12. bisco
    52,286
    good idea.
  13. kiwi
    kiwi Member
    246
    88
    New Zealand
    At least one sober comment about that useless device ....
    Better call it "greed charger" - sounds similar but better reflects the essense ...
  14. bisco
    52,286
    love the self sustaining.
  15. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I found I may have left the rear dome light on, for many days. Been out of town, too! Luckily it didn't die on my mother!
    [​IMG][​IMG]
    Don't forget it's AGM....
    iPad ?
    #15 jzchen, Jun 26, 2015
  16. bisco
    52,286
    ouch! was your battery in the 'purple zone' too?
  17. Mendel Leisk
    41,824
    I'm not sure about, well any of your points. Again, I've only just read up on it, and not that much, but my take is: a grid charger can rebalance a pack, level out the voltage of modules, in a way that in-the-car charging won't do, or not as well.
    That said, they're expensive, install is involved, and effectiveness is up in the air.
    FWIW, our car sat, new, for about 15 months before we bought it. The hybrid battery's been fine, knock on wood.
    Not sure what I'm saying, lol. There's some use for them, but not much?
    tangerino and Paige like this.
  18. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    I'm most concerned with older batteries that sit for a long time.
    For us in Wisconsin, this happens frequently with snowbirds whose cars stay here while their owners go south for the winter.
    The pack can dip below the voltage needed for starting the car.
    Then at that point it is a real headache. The pack gets out of whack. And most dealers do not have a high voltage charger on site. (I do!)
    If people have an older Prius and let it sit for long periods of time, a high voltage maintenance charger is a good idea.
  19. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I don't think so. Had to take my cousin to have a surgery this morning so I didn't check. My mother drove it to work and back....
  20. kiwi
    kiwi Member
    246
    88
    New Zealand
    Toyota's procedure suggests running engine once a month to charge the battery.
    It looks like the issue with depleted packs is happening (rarely) with some other old hybrids.
    I was asked few times this year (one request came from the warm state with no winter) about building higher voltage rescue charger for Lexus and Highlander (288v nominal, either 40 x 7.2V or 30 x 9.6V). Why being bothered inventing the wheel, when Toyota have made those (actually parts are made by Denso and Matshushita). Quite expensive but quality is awesome as usual with those manufacturers. Toyota's rescue charger provides about 1 Amp, constant current and powered by 12V DC (requires about 30 amp power supply). I am currently repackaging them into a small form factor boxes with the plugs compatible with my HV Battery Analysers to accompany my 20-channel Analysers.
    Back to the topic headline:
    Do not buy (waste of money) or install (extremenly unsafe) grid chargers into your Prius.
    Baloney, useless devices for anything else but charging the pack after it has been accidently depleted because of the long storage.
    #20 kiwi, Jun 28, 2015
