Is your electric mileage getting worse? Mine is.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mikenancy1, Jun 6, 2015.
  1. mikenancy1
    mikenancy1 2012 PiP (Base), '10 Highlander Hybrid, '05 Prius
    105
    Geneva, IL
    I do the same commute with roughly the same traffic every workday. I live in Illinois, so my summer mileage is much better than my winter mileage. The past two summers, I'd get 15-17 miles on the electric charge, but this summer I can't seem to get past 13 miles. Is anyone else experiencing something similar, and if so, any ideas on what's causing this?
    51,895
    i think you lose about 10% initially, then the deterioration slows down. i think i'm down from a high of 16.5 or so to 14.5 -15.
  3. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    Bisco do you normally do 120v or 240v charging?
  4. bisco
    51,895
    99% L2 since last fall when i retired. before that, it was about 70/30 L2/L1.
  5. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Reboot to increase range.
  6. 3PriusMike
    3,100
    2,419
    Silicon Valley
    No. You reboot to clear the history and change the displayed value to the factory default.
    Mike
    My 2012 will be 3 years old in about a month. The first two summers I saw my EV range (after many days of my normal commute) around 14 to 14.5 miles. Last year it was 13.something. So far this year I've seen a max of 12.8, but I suspect it will go up a few tenths over the next month.
    Mike
    #6 3PriusMike, Jun 9, 2015
  7. bisco
    51,895
    i was upto 15.2 this spring, but am at 14.5 right now. i suspect the cooler weather the last few weeks. this is the ev estimate though, actual doesn't vary that much.
  8. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    OP
    Are you reporting estimated miles (on the display) or actual miles driven?
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    My median over 2.5 years is about 13 EV miles. It's been as low as 10 on cold winter months and as high as 20 when I drove EV downhill in the summer.
    There is no way you can have identical variables even if your commute has been the same. I did experiments early on for my commute. Left the house roughly everyday at 5AM. Since traffic is minimal at that time anyway, the difference in traffic would be slim. I drove normally and made a mental note of where EV cuts out and switches to HV. I was surprised to find that there was about a 2 mile difference between where EV runs out. (11 to 13 EV miles) I initially attributed it to higher ambient temperature and/or a truck in front of me slowing me down and allowing me to draft. I only drove in the right lane to reduce speed as a variation. I experimented with slower speeds, more drafting, etc. In the end, I realized I was up to the noise of the experiment. 2 miles is how much EV will fluctuate for my morning commute due to variables out of my control.
    In the afternoon? Forget about it. It's a 10-20 mile EV fluctuation. Tons of variable traffic and varying red light durations, temperatures, etc. I'd argue your commute is not the same as the last two summers.
    Chazz8 likes this.
  10. bisco
    51,895
    i was back upto 15.1 yesterday, due to warmer weather, but it's 59 today, so, who knows what tomorrow will bring.
    #10 bisco, Jun 15, 2015
  11. bisco
    51,895
    mike? nancy? hello?
  12. markabele
    5,084
    1,782
    Nebraska
    My two year anniversary has came and went. Just today I did almost 16 miles total (back to the same spot, so no elevation change). And it was raining pretty hard and temps were in the 60's. Pretty sure I could do some 18 and 19 mile trips if all the conditions were right.
  13. bisco
    51,895
    sounds exactly like me.(y)
  14. Witness
    Witness Active Member
    115
    117
    San Francisco Bay Area
    For me, the first year ranged from 13-14 estimated miles. Then it dropped around to 12 and this past couple weeks it has been around 13.3mi. As I understand it, the estimated miles are based on an average of how/where you drive. This would explain the increase from 12mi to 13mi over the last few months.
    On a side note, have you changed your tires? I have Goodyear Assurance tires which are supposed to be okay on my MPG, but it has effectively reduced it by about 5mpg. That will definitely affect your EV miles.
  15. bisco
    51,895
    i'm still on the oem integrities, 70.6 mpg on my last tank.
  16. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    Headline: Prius Plug-In gets more EV miles than a Volt! :)
  17. bisco
    51,895
    sounds like gm wrote the headline for toyota.:cool:
