Prius 3 Interior plastic
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Christian_cool, Jun 9, 2015.
  1. Christian_cool
    Christian_cool Junior Member
    92
    17
    Germany
    Hello everyone! I have a prius from 2010 - 5 years old. The years have leave some marks on the interior plastic which I don't like. So i was considering to sand down the plastic and finish it with find sand paper.
    Have someone done this? Is it a good idea?
    Christian :)
    52,405
    you're going to glue sandpaper to it?o_O
  3. Christian_cool
    92
    17
    Germany
    Maybe if it works ;)
  4. Tideland Prius
    16,623
    I haven't heard of anyone sanding down the interior plastics on this site. Good luck with the project! You'll be the first :)
    Christian_cool likes this.
  5. bisco
    52,405
    don't sand too far, it's pretty thin.:cool:
  6. Mendel Leisk
    41,928
    I'd be more inclined to try an old tooth brush, with a bit of sudsy water. The interior plastic has a distinctive raised texture; I think sanding would take that off, be pretty noticeable.
    Okinawa and Christian_cool like this.
  7. qdllc
    qdllc Senior Member
    1,377
    400
    If you're dealing with scuffs and marks, I'd suggest first trying something mild but abrasive like SoftScrub or GoJo (with pumice). Apply a dab and gently massage the spot with a soft, damp cloth and circular motion. If it comes off, it's all good.
    Be careful it doesn't make too much of a clean spot you'll notice later...seen that happen before. o_O:p
  8. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I've considered using a course wire brush on my interior plastic. The idea being that you could brush out scuffs while maintaining the brushed grain. It's an untested idea.
  9. bisco
    52,405
    but a good one!(y)
  10. qdllc
    qdllc Senior Member
    1,377
    400
    Go with a nylon bristle first.
  11. ChapmanF
    18,569
    I'm with Mendel. Sudsy water, perhaps with quite mild abrasive, maybe even plain toothpaste at first, going perhaps as aggressive as GoJo/pumice if the milder attempts go nowhere.
    The reason for the old toothbrush rather than cloth or sandpaper is the bristles will naturally work the abrasive cleaner all through the 3D texture, but without damaging the texture itself.
    Wire brushes will leave the plastic looking as if your car was home to a cargo of emaciated rats. Sandpaper will leave you with noticeable smooth shiny spots (unless you use really coarse sandpaper, in which case it's back to the rats).
    -Chap
  12. Christian_cool
    92
    17
    Germany
    Thanks for all your replies and suggestions :)
    Where there was scrathes on the interior i tried with a solder gun keep it very close to heat it up (not to much) without touching the scratch area. It worked but to make it 100% clear i would try some of your suggestions :)
  13. bisco
    52,405
    i still like the sandpaper idea.
  14. Christian_cool
    92
    17
    Germany
    I will try it on a part first thats not so visible to see how it looks like. I will post pics when i have done it :)
  15. Eugene Hong
    Eugene Hong Member
    114
    30
    Bay Area, CA
    I really dislike the Prius interior because of how easily it scratches. Please post pictures of your results.
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    You guys are all a lot more adventurous than I would be.
    No way I'd go at The Prius interior plastics with anything like sand paper or wire brushes.
    BUT....
    If you are really inclined to do so?
    May I offer the phrase "Inconspicuous Area Spot Test"?
  17. Christian_cool
    92
    17
    Germany
    I don't like it either, i even put protective tape on the passenger door since my gf don't know how to be careful..
    First result the plastic back part for the handrest console facing rear passengers. It have alot of scratches so i try to sand on this one. I only applied a little force against the plastic when sanding. Later i finished it with find sandpaper. And I try to scrach it afterwards and its better to handle scratches than before. Later i will decide if i want to sand it more down. :) image.jpg
    #17 Christian_cool, Jun 14, 2015
    Priusguy78213 likes this.
  18. Mendel Leisk
    41,928
    So this is after? Not bad. And I can see: the scratches are along the tops of the plastic ridges. Your light sanding has taken off enough to soften the appearance. I'm still leery, but your approach looks to be very careful.
    This reminds me of Photoshop work, cleaning scratches or hairs on film scans: when they overlay a complex pattern it can be very tricky to take them out, without disturbing of the pattern.
  19. bisco
    52,405
    in the long run, it's worth putting up with it for it's veggie based recycle ability.
  20. swbsam
    swbsam Junior Member
    san diego ca
    I personally don't have any problems doing things to protect the interior of my car as in seat covers, molded dash cover Weather tech floor mats but going after the plastic with sand paper not for me.
    Just as there are companies that do Paintless dent removal there are also companies that specializes in interior repair, every car dealer use is them, haven't you ever wondered when you walk onto a used car lot how these cars look like brand new inside?
    I've used guys like this a couple of times, they are mobile, they will drive right to your home and do the work in your driveway (providing you're not hundreds of miles from were most of the car dealers are, and when they are done the interior looks like new again. 20140605_130946.jpg 20140605_130918.jpg
