Stock Tire Mileage
Discussion in 'Gen 3 Prius Fuel Economy' started by EchoToPrius, Jun 13, 2015.
  1. EchoToPrius
    EchoToPrius Junior Member
    BRIDGESTONE
    ECOPIA
    Just took them off today. Got 91,250 miles out of them.
    Anyone else here got 90,000 + out of their tires?
    52,407
    wow! rode hard and put up wet.(y)
  3. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    That is very good. Hope I get that out of my Ecopia ep20 tires as they are a very good fe tire.h
  4. Mendel Leisk
    41,928
    Dang it: "Bridgestone Ecopia" is not a tire. C'mon, complete the description please.
    I'm ok now... Assuming they're Ecopia EP20, that mileage is phenominal. How much tread depth was there, gotta assume you didn't get much snow. Assuming you ran them down to the wear bars, and then some, and not sure that earns a merit badge, lol. I'd much rather swap out tires when they're anywhere less than 5/32" remaining.
  5. Markee
    Markee Member
    336
    South Florida Broward County
    I just bought a used 2013 level 4 with about 16k miles and the Ecopia ep20 tires on it have around 6/32" left on them
    What PSI do you guys or most people run on them ?
    Has anyone had any luck when you swap out the Original tires getting them discounted or pro-rated ?
    Original inception date of the car was 02/17/2014
  6. sisharp
    sisharp Member
    46
    29
    South Carolina
    Wow that's great. You probably did wear them down way past wear bars and into rims for a few miles :) I got close to 60 on mine but I still had water channels. It rains a bunch here so I couldn't go lower.
  7. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    What air pressure did you use? Did you go higher like so many seem to do?
  8. CR94
    CR94 Senior Member
    2,756
    1,208
    Northwestern S.C.
    It seems a bit hasty to make that accusation without better evidence. I used to routinely go over 100K miles without getting into the wear-out bars---although on much lighter cars.
  9. EchoToPrius
    44 psi all the way around
    down to the wear bars but not past
    95% freeway / highway mileage
    I rotated my tires every 10k miles
    They could have easily gone for 100+
    But I decided to replace them with michelin energy saver as
    Priusguy78213 likes this.
  10. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    Nice; just got my 2013 recently. Did some research and it looks like the Michelin energy saver a/s should be just about the best tire for it. Great reviews. One of the first things I did when I got my car a few weeks ago; all new Michelins. It had mismatched tires; Coopers (almost new) in the front and I forget what up front; almost bald. So far so good on these Michelins. Nice, smooth ride, pretty quiet. I'll be shooting for that 90,000+ mileage; fingers crossed ; )
  11. Mendel Leisk
    41,928
    Just for the record, these are Ecopia EP20? Tick yes [], or no [], lol.
  12. EchoToPrius
    yes,stock tires that came on the car
  13. Mendel Leisk
    41,928
    Here's a snapshot of Bridgestone Ecopia EP20, with maybe 4/32" remaining tread depth. They're legal, but my take, it's like driving at dusk with no headlights, not commendable. Don't even think about dealing with snow with these, they're essentially racing slicks. This was just before I took those rims and got replacement, same tire for that matter.
  14. lester williams
    227
    68
    mississippi
    Hhmm, Mendel, looks like some toe-in correction was needed also.
  15. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Those look like my EP20's at 73k miles. There's no snow or rain in sunny CA no matter how much I pray for it. No precipitation whatsoever. I'll probably run on these for another 20k miles to the wear bars.
  16. Mendel Leisk
    41,928
    I'd put it down to rear camber, not 100% sure tho.
  17. orenji
    orenji Senior Member
    5,887
    3,488
    Mendel - i will buy thoses tires off you, they still look good to me! ;)
  18. Former Member 68813
    3,524
    983
    US
    that's the key here. i never ever got more than 30,000-40,000 miles from a stock tire driving mostly in city.
  19. FLteacher
    FLteacher Junior Member
    75
    I need new tires, and the Michelin energy saver is not available right now. Would you recommend the Bridgestone Ecopias? I've been looking for a week, and two Costcos have called Michelin for me, and the Energy Savers are on back order.
  20. Mendel Leisk
    41,928
    Ecopia EP20 are good for mpg, right from the start. Decent tire. ONY come in 195/65R15. In that size I'd pick them as opposed to EP422.
    FLteacher likes this.
